Robotics Researcher
Job description
As Robotics Engineer you will be working closely with expert teams on the implementation of state-of-the-art Robotics solutions. You will develop, implement and test software algorithms and improve existing algorithms. We are looking for robot motion-planning engineers and control engineers.
Depending on your skills and preferences, the accent of your job will be either on control or on path planning.
Responsibilities:
  • You will be responsible to create, maintain and integrate software components for high-end robotic projects.
  • Create reusable and efficient code for robotic applications, involving
  • Vision-based localization (VSLAM)
  • You will create and improve the localization and mapping of the robotic vehicles using LIDAR and camera.
  • Motion planning and collision avoidance software
  • Sensor fusion and obstacle detection
  • 3D vision software and deep learning
  • Testing the software extensively on simulation and/or hardware platforms
  • Mentors junior engineers via pairing, design review, and code review.
What You Will Do:
  • Develop (multi-agent) motion planning and decision-making systems (motion-planning engineer).
  • Develop custom motion control algorithms for different applications, e.g. path tracking/following, formation driving. (robot motion control engineer).
  • Build robust solutions to cutting-edge control problems.
  • Improve how our mobile robots act and react in complex and nuanced situations.
  • Integrate robotics with peripherals, such as (automatic) roller-belts, controllers, or other equipment.
  • Provide technical support for robotic systems.
  • Develop and conduct tests for Computer Vision algorithms
  • Program autonomous robots and robotic arms for repeatable tests in controlled environments
  • Combine sensor data of various tracking and scanning systems
  • Develop and test sensor calibration algorithms.
Who are you:
MSc or Ph.D. in Robotics, Computer Science, Control, Mathematical Engineering Aerospace, Mechanical Engineering, Mechatronics, Electrical Engineering, Computer Science, or Industrial Automation.
  • 3+ years of professional work experience as an engineer
  • 5+ years of programming experience in C, C++, Python, or Matlab
  • Strong mathematical background.
  • Excellent Research paper writing skills.
  • You understand the basics of kinematics (e.g. a transformation), sensor fusion, and optimization.
  • You can work independently while being a team player with good reporting skills.
  • Profound knowledge about robot motion-planning techniques and control systems state estimation. (robot motion-planning engineer).
  • Experience with SLAM or visual tracking systems
  • Experience with ROS / ROS2 / ROS Industrial (robot operating system) or similar
  • Experience with programming robotic arms (KUKA or others)
  • Experience with programming clearpath rovers.
  • Experience with point cloud processing
  • Web programming and scripting experience
  • Experience with sensor (camera, …) calibration
  • Track record of successful projects showing computer vision and robotics skills
  • Knowledge about the latest technical developments in this field.
  • Excellent programming skills.
  • English (written & verbal)
This post doesn’t seem to mention the name of the company, its website, or how to apply.
Or location :slight_smile:
something something 20 characters
Hi Salman,
Are you posting this job for your employer or are you posting it as a third party recruiter?
