Many IDEs will have some kind of debugger or profiler built in, but with ROS, there are few IDEs to choose. Therefore it’s important to understand how to use these raw tools you have available rather than relying on an IDE to provide them.
While gdb CLI is great when your in a tight spot or just want to quickly inspect a crash, I still find IDE debuggers advantageous for deeper debugging sessions, where code model navigation goes well with interactive breakpoints, and GUI visualizations help me inspect the call stack and memory contents at a glance. That said, it’s still not as straightforward to use for the same reasons stated in the tutorial, given ROS’s extensive use of launch orchestration tooling and dynamic runtime parameters.
https://doc.qt.io/qtcreator/creator-debug-mode.html
Perhaps it might be worth adding a section to demonstrate attaching a debugger to an already running ROS process. This alleviates the need to alter the launch sequence, though isn’t as helpful if the node in question crashes before you can attach or when it is the startup of the process you wish to debug.
In such circumstances, if the node itself is relatively stateless with the rest of the subsystem, I can get away with letting that one node among many in the launch file crash, then read from the ros launch traceback over stdout to copy the process commands invoked by roslaunch itself and paste them into the program arguments for a new debugger session. A caveat is that roslaunch passes parameters via temporary yaml files which also go out of sync if you happen to alter the deriving launch files.
QT Creator
Clion
It would be nice to have some sort of IDE integration that could hint to roslaunch which processes is marked for debugging, as having to single out a particular node from a nested set of launch files and reproduce the same startup environment from a separate shell session is a bit tedious.
P.S. if anyone knows a way to force roslaunch to always show the underlying commands used to spawn orchestrated processes without needing the respective node to crash, that’d be awesome.
