ROS 2 not found test_pluginlib/local_setup.sh
Hello!
I have installed from sources Crystal Clemmys following the instructions from here: ROS 2 Crystal Clemmys call for testing and package releases
My system is:
lander@wks4:/media/lander/Datos1/github/ros2_crystal$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 16.04.4 LTS
Release:	16.04
Codename:	xenial
I have compiled changing the tag to master. As explained in the docs. I compiled using the following command:
colcon build --merge-install
No problems with the compilation :). When I source my workspace as follows:
lander@wks4:/media/lander/Datos1/github/ros2_crystal$ source install/setup.bash
not found: "/media/lander/Datos1/github/ros2_crystal/install/share/test_pluginlib/local_setup.sh"
not found: "/media/lander/Datos1/github/ros2_crystal/install/share/test_pluginlib/local_setup.bash"
I got the warnings shows above. I think is not a problem because I’m able to run the demos using Fast-RTPS and OpenSplice rmw implementations. Is just to inform you.
Thank you!
Regards,
@LanderU
ROS Discourse is about News and general discussion about ROS. Kind of like the “ros-users” of discourse.ros.org.
If you have a question: Please ask on http://answers.ros.org following our support guidelines. This is not the right place.
–> https://answers.ros.org/questions/scope:all/sort:activity-desc/page:1/query:crystal/
Hi @ThiloZimmermann,
sorry, bad place for the question.
Thank you!
Regards,
@LanderU
