ROS 2 port of mqtt_client, a C++ node for bi-directionally bridging messages between ROS and MQTT
We are happy to announce that mqtt_client , first released a year ago, has now been ported to and released for ROS 2 Humble, Iron, and Rolling!
The mqtt_client package provides a ROS node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using the MQTT protocol . This works generically for arbitrary ROS message types.
Main features:
  • C++ node for high performance and memory efficiency
  • support for arbitrary ROS message types through the use of generic publishers and subscribers
  • support for many MQTT features like QoS levels, authentication, and encryption
  • extensive configuration options on both the ROS and MQTT side
  • support for exchanging messages of primitive data types with other non-ROS MQTT clients
  • built-in functionality for measuring the latency of transferring a ROS message via an MQTT broker back to ROS
Below you can find a minimal configuration for sending any message on ROS topic /ping to MQTT topic pingpong and back to ROS topic /pong on a single machine. A real use case would naturally involve more ROS-based machines.
Feel free to check out the Quick Start from our GitHub repository or the ROS Wiki page !
mqtt_client:
  ros__parameters:
    broker:
      host: localhost
      port: 1883
    bridge:
      ros2mqtt:
        ros_topic: /ping/ros
        mqtt_topic: pingpong
      mqtt2ros:
        ros_topic: /pong/ros
