The tag checking on answers.ros.org seems to be case sensitive. Entering “ros1” and “ROS1” isn’t the same (and the latter comes as a suggestion while entering “ros1”).
Shouldn’t the tags be case-insensitive anyways? If no, the tag suggestions should be cleaned up
