Here are the minutes for the meeting held on 2019/07/03.
Participants
- Geoffrey Biggs (Tier IV/The Autoware Foundation)
- Jacob Hassold (DCS)
- Lalit Begani (Intel)
- Matt Droter (ROS Agriculture)
- Shawn Schaerer (Northstar Robotics)
- Sohin Shah
- Victor Mayoral (Acrutronic Robotics)
Discussion
- Reviewed ideas that have been thrown around so far
- Sohin gave a presentation on the small lawn tractor application from ROS Agriculture that we are considering for our reference application
- ros_lawn_tractor_safety.pdf (1.1 MB)
- A retrofitted lawn tractor, with a Rasperry Pi 3 providing the ROS master and an NVIDIA Jetson Nano for the AI-based perception.
- The use case is to cover an area while avoiding obstacles
- The response to (dynamic) obstacles is to just stop and wait for the operator to help
- Current safety features are:
- An estop; loss of power to this relay kills the engine
- A remote kill switch
- A tele-op deadman switch
- Ultrasonic range sensors are planned
- The navigation stack (in ROS 1) has disadvantages for safety, e.g.:
- The stop response for obstacles causes the local planners to enter recovery behaviours, which eventually leads to the goal being abandoned.
- Declaring an emergency doesn’t mean anything unless the nodes performing their actions are actually killed.
- They have designed three different levels of safety threats
- They have a lot of questions about how to do safety properly
- They lawn tractor is being used in an agriculture robot challenge (agBOT Challenge), which has quite well-defined environments and goals that could be useful to define a reference application
- Acutronic has a sample use case they have been using for their security work
- They are putting together a simple pick-and-place use case using a simple modular robot arm
- The use case is fairly detailed and an excellent starting point for doing safety work
- To be clear, we do not intend to produce a set of general safety documentation for using ROS in a safety-critical system, but provide safety documentation for the ROS-related parts of a specific application on a specific robot as an example of how
- There is an EU project for security and safety being proposed by Acutronic Robotics called RECLAIM
- If the project gets funded, then Acutronic Robotics believes they can bring in some experts in safety for robotics to contribute to the working group
- Funding result is expected to be known by the end of the year
