I agree, that missusing messages and services is a tempting thing when prototyping software and it often doesnât get replaced later on.
However, I like to see those very simple services kind of the same as c++ functions. If you take the setBool service for example. You would create a service called e.g. set_detection_enabled of type SetBool
In c++ you would create a function called set_detection_enabled which takes a bool as an argument.
Now you could create a custom service type, letâs name it SetDetectionEnabledStatus which has a boolean field called is_enabled. This is how I understand the counter-general-services position above.
Taken back to c++ terms I understand this as a typdef from bool to detection_enabled_status which doesnât feel quite right to me.
As soon as I would pack something into a struct or class or enum in c++ I agree, that it does make sense to also define itâs own message type. This also fits together with Tullyâs example that you could in theory use an image for a pointcloud, but you wouldnât.
Another point is that everybody knows how to use these standard types. If we go back to my example and letâs say, we created a service called SetDetectionEnabledStatus, itâs not clear from the type which states are actually allowed. It could also contain an enum field with 20 different states. If itâs just of type SetBool, then everybody knows the two possible values just by looking at the type.
I am very well aware that the SetBool service does exist in std_srvs and Iâv been cloning the repo to my workspaces a couple of times before it was released as package, however I think that the same argumentation goes for something like setFloat, setInt and so on. To quote a colleague: A float is a float, is a float. If you decide to call a service called set_distance with a measurement received from a humidity sensor or from a random number generator, thatâs ok. I think it is quite obvious, that this probably wonât produce the desired behavior, however.
TLDR: I would prefer to have predefined set and trigger services with basic datatypes, however I see the risk of tempting people to kind of missuse datastructures out of pure lazyness and that this should be prevented as good as reasonable (reasonable as in the bool typedef example).
