ROS 2 TSC Meeting Minutes: 18 April 2019
- Attendees:
- Allison Thackston (TRI)
- Brian Gerkey (Open Robotics)
- Brian Shin (LG Electronics)
- Dejan Pangercic (Apex.AI)
- Dirk Thomas (Open Robotics)
- Filipe Rinaldi (Arm)
- Geoffrey Biggs (Tier IV)
- Jaime Martin Losa (eProsima)
- Jonathon Smereka (TARDEC)
- Karsten Knese (Bosch)
- Louise Poubel (Open Robotics)
- Matthew K Hansen (Intel)
- Rutvik Hora (Amazon)
- Seonman Kim (LG Electronics)
- Tully Foote (Open Robotics)
- Victor Mayoral Vilches (Acutronic Robotics)
- Old business:
- [2 min] [Brian] ROS trademark update
- Brian providing usage specimens to lawyers for filing.
- TSC: volunteers to form small group to work on usage policy?
- Geoff
- Jaime
- Brian
- [2 min] [Brian] Elevator pitch
- Brian iterating on draft with layout designer. Should have something ready in the next week or so.
- Brian to integrate links (comment from Matt H.)
- [2 min] [Brian] TSC content in ROS 2 docs
- Live: https://index.ros.org/doc/ros2/Governance/
- Update Safety lead to Geoff
- [2 min] [Dirk] Transition plan from waffle.io
waffle.io shuts down May 16 (https://waffle.io/)
- Want public state to determine the status of the board.
- Also want multiple organizations in a single board, but might not be achievable.
- New business:
- Working group document storage and communication channel
- We’ll continue a thread in Discourse, tentatively looking at adding discourse categories to collect working groups in a hierarchy.
- [2 min] [Brian] Open Robotics hiring Evangelist
- [15 min] [Brian] Dashing release communication plan
- Planned Support Cycle:
- LTS: 2 years
- Features: need to accumulate key feature list
- Google doc for commenting open to everyone
- Brian to set that up
- Demos: who has demos to include?
- Several TSC members planning to include demos, aiming for screenshots, videos, narrative text, and/or tutorials describing how to replicate the work.
- Demos from outside the TSC also welcome!
- Standing updates:
- [15 min] [All] Release planning - dashing update:
- Apex.AI
- Testing and launch improvements
- Performance Testing
- Acutronic Robotics
- Real-Time
- Work already started, expecting a first version with selected platforms for June (Dashing)
- Information models
- Coliza released https://github.com/AcutronicRobotics/HRIM/releases/tag/Coliza
- Motion planning progress: https://github.com/AcutronicRobotics/moveit2#progress
- Articles describing the process and raising awareness: MoveIt 2 porting progress articles
- CI https://github.com/AcutronicRobotics/moveit2#continuous-integration-status
- Docker containers (for CI purposes) https://github.com/AcutronicRobotics/moveit2#docker-containers
- Install instructions https://acutronicrobotics.com/docs/products/robots/mara/moveit2/install/ubuntu
- Real-Time
- Bosch
- Ongoing work with diagnostics. Waiting for PRs to be merged.
- Preparing buildfarm CI job to build rosbag2.
- Amazon
- QoS PRs in progress. Working end to end with RTI & OpenSplice
- Testing in progress against FastRTPS v1.8 that supports these QoS
- Security threat model is merged. Contributions from Acutronic for MARA
- ASAN/TSAN jobs are running. Our team is working on stack ranking and fixing issues.
- eProsima
- Deadline, lifespan, and liveliness QoS Supported on Fast RTPS 1.8
- Static Memory allocations. It is a WIP, but discovery allocations will be all static in Fast RTPS 1.8, and many others.
- Open Robotics
- IDL support landed
- 3rdparty generators need updates
- Rospy generated content now leverages numpy might be API changes
- Intraprocess efficiency/performance improvements
- C++ API for composable nodes
- Launch support for loadable components
- New generation of Launch API
- Read Only Parameters
- XML frontend for Launch(might fall back)
- Range support for Parameters, in process by at risk for feature freeze deadline.
- Fixed rclpy memory leak, expect backport
- rosbridge_suite port is ongoing
- Infrastructure and CI jobs improvements
- Support for generating RPM spec files expected
- LG Electronics
- In Progress: OpenEmbedded Platform support
- Merged PRs to rosdep and rospkg that were needed for OpenEmbedded
- Submitted PR for superflore upstream, under review
- Have reference HW demo on Raspberry Pi 3 with set of Crystal packages using superflore automatically generated recipes
- Working on extended Crystal package support (currently 275 packages)
- Will build Dashing packages now that Dashing distribution index has been released
- Microsoft
- Working with Open Robotics on ROS 2 release logistics for the Windows side, including how to host chocolatey packages, ROS bridge and vcpkg integration.
- Stood up a colcon build on Azure DevOps
- We’re going to add an installer to rosdeps so that when a chocolatey package is not available, rosdep will consult vcpkg to see if a recipe is available and offer to download, build and install.
- Working on a vcpkg feature to export chocolatey packages
- Apex.AI
- Working groups:
- [5 min] [Matt H] Navigation
- Added Obstacle Layer - still doing some tuning
- Converting nodes to lifecycle nodes, for improved bring up / shutdown reliability - in code review
- Converting to using Actions across the stack
- Adding recovery behaviors via behavior tree
- Adding parallel planning
- Moving to using BehaviorTree_CPP v3.0
- Support integration of system test into ROS2 build farm? (need to discuss)
- Issue: https://github.com/ros2/ros2/issues/607
- Line: CI for simulation-based testing of navigation
- [5 min] [Rutvik] Security
- Threat Model is merged, Turtlebot and MARA models
- Setting a 2 week cadence for ongoing meetings
- [5 min] [Dejan] Real-time and safety
- ROS 2 and Real-time
- Reference hardware platforms
- Using the H-ROS SoM
- [5 min] [Karsten] Embedded
- No updates as for now. Preliminary work has to be done before the next meeting, presumingly in May.
- [5 min] [Víctor] Motion planning WG Suggestion
- Discussion of plans and planned actions, input from TSC
- Late new business:
- [Rutvik] armhf (32-bit ARM) support
- Seeing demand for armhf
- Looking to improve the toolchain
- ARM interested in supporting this
- Also of interest to Apex to avoid requiring hardware, all platforms are arm based
- Target Tier 3 to start, want to push it up to at least Tier 2
- [Brian Shin] Definition and requirements for new platform support
- Rep-2000: http://www.ros.org/reps/rep-2000.html
- OpenEmbedded as Tier 3 platform
- Would like more definitions for what the requirements are for the tiers.
- A process for being selected/supported would be valuable
- [Karsten] State of real time within ROS 2
- State of executor
- How can we approach proposing changes to this?
- Design Doc or PR proposals are best or go through working doc
- ROS 2 and Real-time discourse post
- State of executor
- New TSC member inquiries
- Looking for ways to engage, how can they get involved? What can we send them? They’re looking for chunks of work to pick up to demonstrate interest.
