Turrtlebot3 and OpenCR Fx0200 error
All -
I am trying to updated OpenCr by following these instructions
http://emanual.robotis.com/docs/en/platform/turtlebot3/opencr_setup/
I keep encountering following error after running these steps.
export OPENCR_PORT=/dev/ttyACM0
export OPENCR_MODEL=burger
rm -rf ./opencr_update.tar.bz2
wget https://github.com/ROBOTIS-GIT/OpenCR-Binaries/raw/master/turtlebot3/ROS1/latest/opencr_update.tar.bz2 && tar -xvf opencr_update.tar.bz2 && cd ./opencr_update && ./update.sh $OPENCR_PORT $OPENCR_MODEL.opencr && cd ..
Here is the output I am getting.
Resolving github.com (github.com)… 192.30.253.113, 192.30.253.112
Connecting to github.com (github.com)|192.30.253.113|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://raw.githubusercontent.com/ROBOTIS-GIT/OpenCR-Binaries/master/turtlebot3/ROS1/latest/opencr_update.tar.bz2 [following]
–2019-01-27 18:11:28-- https://raw.githubusercontent.com/ROBOTIS-GIT/OpenCR-Binaries/master/turtlebot3/ROS1/latest/opencr_update.tar.bz2
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.0.133, 151.101.128.133, 151.101.192.133, …
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 400666 (391K) [application/octet-stream]
Saving to: ‘opencr_update.tar.bz2’
opencr_update.tar.b 100%[===================>] 391.28K 20.4KB/s in 16s
2019-01-27 18:11:45 (24.9 KB/s) - ‘opencr_update.tar.bz2’ saved [400666/400666]
opencr_update/burger_turtlebot3_core.ino.bin
opencr_update/open_manipulator.opencr
opencr_update/waffle_turtlebot3_core.ino.bin
opencr_update/opencr_ld_shell_arm
opencr_update/update.sh
opencr_update/
opencr_update/released_1.2.3.txt
opencr_update/waffle.opencr
opencr_update/opencr_ld_shell_x86
opencr_update/burger.opencr
opencr_update/open_manipulator_turtlebot3_core.ino.bin
armv7l
arm
OpenCR Update Start…
opencr_ld_shell ver 1.0.0
opencr_ld_main
[ ] file name : burger.opencr
[ ] file size : 178 KB
[ ] fw_name : burger
[ ] fw_ver : 1.2.3
[OK] Open port : /dev/ttyACM0
[NG] cmd_read_board_name fail : 0xF020
[ ] fw_ver : 1.2.3
[ ] fw_ver : 1.2.3
I am now have the same issue on two of my boards. Not updating anything until this is solved.
I think that connecting OpenCR to PC is something wrong.
If you have a issue with turtlebot3, please visit our github. https://github.com/ROBOTIS-GIT/turtlebot3/issues
We will help you.
I guess this should be posted at https://answers.ros.org/questions
Actually the answer: (EDIT RTFM page 248 :wink: (reset and switch 2 then reset boot, and all is fine
In there E-manual it can be found here: after Section 7 Recovery mode
http://emanual.robotis.com/docs/en/parts/controller/opencr10/#references
cd ./opencr_update ./update.sh $OPENCR_PORT $OPENCR_MODEL.opencr
Results:
OpenCR Update Start …
Wrong parameter
update.sh fw_name
Questions: Can u help me fix it in detail? Tks so much
Hi! this is a 5 year old post and on discourse there is no support handling, only discussions about development goals about of the ROS ecosystem and news/announcements.
You should ask this question on https://robotics.stackexchange.com/ or the right github issue list.
Thank you very much
Best regards,
Duy
Vào Th 6, 29 thg 9, 2023 lúc 14:51 Kimberly McGuire via ROS Discourse <notifications@ros.discoursemail.com> đã viết:
