Dear ROS users,
Iβd like to announce the rrt_exploration package. It is a ROS package that implements a multi-robot RRT-based map exploration algorithm. It also has the image-based frontier detection that uses image processing to extract frontier points.
You can use it to make you robot do exploration. It can be used on a single or multiple robots.
Hello echotor,
After ypu run the launch file, you have to define the region in which exploration will take place, and also the starting point for the detectors. This can be done by publushing five points from rviz. The first four define a rectangular region, and the last point is the starting point.
I met this problem when I run roslaunch rrt_exploration single.launch:
process[assigner-4]: started with pid [2735]
File "/home/wangyawei/RosWorkspace/rrt_exploration_ws/src/rrt_exploration/scripts/filter.py", line 67
for i in range(0,n_robots):
TabError: inconsistent use of tabs and spaces in indentation
[filter-3] process has died [pid 2728, exit code 1, cmd /home/wangyawei/RosWorkspace/rrt_exploration_ws/src/rrt_exploration/scripts/filter.py __name:=filter __log:=/home/wangyawei/.ros/log/c300c286-92ae-11e7-8bc9-f48e38f12209/filter-3.log].
log file: /home/wangyawei/.ros/log/c300c286-92ae-11e7-8bc9-f48e38f12209/filter-3*.log
File "/home/wangyawei/RosWorkspace/rrt_exploration_ws/src/rrt_exploration/scripts/assigner.py", line 5, in <module>
import rospy
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/__init__.py", line 49, in <module>
from .client import spin, myargv, init_node, \
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/client.py", line 52, in <module>
import roslib
File "/opt/ros/kinetic/lib/python2.7/dist-packages/roslib/__init__.py", line 54, in <module>
import roslib.stacks
File "/opt/ros/kinetic/lib/python2.7/dist-packages/roslib/stacks.py", line 46, in <module>
import roslib.packages
File "/opt/ros/kinetic/lib/python2.7/dist-packages/roslib/packages.py", line 49, in <module>
from catkin.find_in_workspaces import find_in_workspaces as catkin_find
File "/opt/ros/kinetic/lib/python2.7/dist-packages/catkin/find_in_workspaces.py", line 36, in <module>
from catkin_pkg.packages import find_packages
ModuleNotFoundError: No module named 'catkin_pkg'
[assigner-4] process has died [pid 2735, exit code 1, cmd /home/wangyawei/RosWorkspace/rrt_exploration_ws/src/rrt_exploration/scripts/assigner.py __name:=assigner __log:=/home/wangyawei/.ros/log/c300c286-92ae-11e7-8bc9-f48e38f12209/assigner-4.log].
log file: /home/wangyawei/.ros/log/c300c286-92ae-11e7-8bc9-f48e38f12209/assigner-4*.log
The first error I think is source code format problem. I hope you could check the source code.
For the second, I run pip install catkin_pkg but nothing help. And the error still exist. This is my result of install:
wangyawei@wangyawei-pc:~/RosWorkspace/rrt_exploration_ws/src/rrt_exploration$ pip install catkin_pkg
Collecting catkin_pkg
Downloading catkin_pkg-0.3.6.tar.gz (44kB)
100% |ββββββββββββββββββββββββββββββββ| 51kB 414kB/s
Collecting argparse (from catkin_pkg)
Downloading argparse-1.4.0-py2.py3-none-any.whl
Collecting docutils (from catkin_pkg)
Downloading docutils-0.14-py2-none-any.whl (543kB)
100% |ββββββββββββββββββββββββββββββββ| 552kB 1.3MB/s
Collecting python-dateutil (from catkin_pkg)
Downloading python_dateutil-2.6.1-py2.py3-none-any.whl (194kB)
100% |ββββββββββββββββββββββββββββββββ| 194kB 541kB/s
Collecting six>=1.5 (from python-dateutil->catkin_pkg)
Downloading six-1.10.0-py2.py3-none-any.whl
Building wheels for collected packages: catkin-pkg
Running setup.py bdist_wheel for catkin-pkg ... done
Stored in directory: /home/wangyawei/.cache/pip/wheels/6c/ae/84/bea62c6c5c4334ceb4306854c5294801305858a1cc021dc219
Successfully built catkin-pkg
Installing collected packages: argparse, docutils, six, python-dateutil, catkin-pkg
Successfully installed argparse-1.2.1 catkin-pkg-0.3.6 docutils-0.14 python-dateutil-1.5 six-1.10.0
You are using pip version 8.1.1, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
We work to keep the general category here on ROS Discourse for announcements and other general interest discussions.
You can link to it from here so others who find this thread will find your question. (If you edit your above post it wonβt resend emails to everyone.)
Hi Hassan,
thank you for sharing that interesting package. We believe that is is very well packaged and works fine off-the-shelf (at least in our case).
We created this video showing how to install and how to use it from your git links above. We found no problem installing and executing it. We plan to create other videos showing how to apply the package to other robots. We will keep you informed.
@hasauino thanks for sharing. do you have any hints about locations where the corresponding paper can be found? I followed the link for the βthesis titleβ as listed at http://wiki.ros.org/rrt_exploration, but it leads to a page that requires special permissions to get the paper. The URI listed on that page is http://hdl.handle.net/11073/8857
The paper which describes the algorithm is still not published. However, itβs been accepted to be published in IROS 2017 which will be held on 24th Sep.
