The first alpha for the next version of Autoware, 1.12-alpha.1, is now available for testing. We encourage all Autoware users to try it out and wring out any remaining bugs before the code-freeze date of June 24th.
Get the source from the repository and install it using the from-source build instructions.
Docker images are available at dockerhub:
https://hub.docker.com/r/autoware/autoware/tags
https://hub.docker.com/r/autoware/amd64/tags
The following changes have been made since 1.11.
- MPC waypoints follower (#2252)
- Fix setting files for rosbag demo (#2249)
- Modify stop states (#2255)
- Fix autoware launcher readme. (#2253)
- Split drive state (#2251)
- melodic support (#2032)
- add battery charging state (#2256)
- modify mssion state for fms (#2257)
- add install to the resources and plugin.xml (#2287) (Fixes #2147)
- Add tests around Openplanner utilities (#2262)
- Support full functions of g30esli_interface (#2139)
- Update Docker cross-build Image (#2270)
- add predicting convex hull (#2254)
- Fix Segmentation fault at velocity_set by asynchronous base_waypoints and closest_waypoint (#2152) (#2272)
- Fix gazebo not found in colcon_release_cross synquacer (#2268)
- fix behavior_state in imm_ukf_pda_track (#2240)
- runtime_manager: change params definition from int to float (#2266)
- Fix don’t show run time in runtimemanager #2229 (#2235)
- ekf_localizer (#2247)
- [fix]: make sure cost is set with expanding_polygon_size (#2245)
- Remove points2costmap (#2248)
- fix install directive for waypoint extractor (#2219)
- Adding install directive for node (#2195)
- Fix bug that limits the data rate of DataRateCheckerPlugin (#2205)
- Updated paths in quick_start launch files and parameters in default.rviz (#2206)
- Remove enablePlannerDynamicSwitch (#1919)
- Add .repos file for setting up an Autoware workspace using vcs (#2161)
The following changes planned for 1.12 have not yet been made (we expect to do a second alpha for these in the next couple of weeks). You can follow progress on the 1.12 milestone.
- Split repositories and shift to using
vcs
for install - Clean up the quick start documentation
