Yes I know you want people to use apt-mirror but I can’t. I need to run a mirror on a production machine that is CentOS based and has tight restrictions. This mirror uses rsync to mirror third party repositories. This is efficient and trusted.
I can rsync all parts of ros.org except for the packages because the packages directory is a link that is not followed by the rsync server. You can test this using the command: rsync -azv rsync.osuosl.org::ros/packages.ros.org/ros/ubuntu /tmp/ros
I have made a request to osuosl.org to fix this since all their other hosted projects support rsync but they have implied that the server is controlled by OSRF. So can you guys fix this?
We’ve made the request but I haven’t heard an ETA from OSUOSL for resolving the error. I don’t know if it’s a matter of changing a config or if all the files will need to be shuffled.
@tfoote: would you perhaps have an update on this rsync-related topic as well?
Similar to @boilerbots, my university’s mirror admins (TU Delft) prefer (require) rsync as it integrates with the rest of the mirroring infrastructure (Debian, Ubuntu, Gentoo, etc). Hence the question.
Edit: should this thread be moved to the Mirrors category btw?
