Did kinetic support novatel gps
Dear preed
I got this problem
rostopic echo /bestpos
ERROR: Cannot load message class for [novatel_gps_msgs/NovatelPosition]. Are your messages built?
I did source devel/setup.bash before
Thanks
preed
September 8 |
I haven’t seen errors like that before. Those look a little strange; are you able to compile other catkin packages from source without problem? Have you tried using catkin_make to compile novatel-gps-driver instead?
Although, I also see this:
Call Stack (most recent call first):
/opt/ros/jade/share/tf/cmake/tfConfig.cmake:165 (find_package)
/opt/ros/jade/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
If you are using ROS Jade, novatel-gps-driver has actually already made it into its release repository, so you may be able to simply do sudo apt-get install ros-jade-novatel-gps-driver and skip compiling it from source.
Visit Topic or reply to this email to respond.
In Reply To
wenlong
September 8 |
Hi, Preed, I used catkin_tools, but it said that: Errors << novatel_gps_driver:cmake /home/robot/novatel/logs/novatel_gps_driver/build.cmake.002.log CMake Error at /home/robot/Documents/ros/devel/share/tf2_ros/cmake/tf2_rosConfig.cmake:106 (message): Project ‘tf2_ros’ specifies ’/home/xiaoq…
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
