Seems to me that http://prerelease.ros.org/ is stuck.
Are the scripts generating the command publicly available?
@wjwwood Any information on this?
The information in ros-infrastructure/ros_buildfarm/doc/jobs/prerelease_jobs.rst should be sufficient to run everything locally.
Can you be more precise, what part is stuck? All of the code is open source: GitHub - ros-infrastructure/prerelease_website
I think that @agutenkunst is referring to step 3 (Select Dependents to Test) that does not finish in reasonable time.
I have the same issue which I can reproduce with these steps:
std_msgs
@wjwwood The prerelease command generator is still “stuck”.
@agutenkunst You might get more luck by opening an issue at https://github.com/ros-infrastructure/prerelease_website/issues.
I know this topic is quite old, but I wanted to point out that we just looked into this and made the necessary fixes on http://prerelease.ros.org . So this should be working again; please open a new issue on GitHub - ros-infrastructure/prerelease_website if you have further problems.
