We’re happy to announce 16 new packages and 73 updated packages for Kinetic. Details are listed below.
Thank you to all the maintainers and contributors who have helped make these packages available!
Package Updates for kinetic
Added Packages [16]:
- ros-kinetic-haros-catkin: 0.1.1-1
- ros-kinetic-lex-common: 1.0.0-1
- ros-kinetic-robot-statemachine: 1.1.3-1
- ros-kinetic-ros-mppt: 0.1.1-1
- ros-kinetic-rsm-additions: 1.1.3-1
- ros-kinetic-rsm-core: 1.1.3-1
- ros-kinetic-rsm-msgs: 1.1.3-1
- ros-kinetic-rsm-rqt-plugins: 1.1.3-1
- ros-kinetic-rsm-rviz-plugins: 1.1.3-1
- ros-kinetic-rxcpp-vendor: 4.1.0-1
- ros-kinetic-seed-r7-bringup: 0.2.0-2
- ros-kinetic-seed-r7-description: 0.2.0-2
- ros-kinetic-seed-r7-navigation: 0.2.0-2
- ros-kinetic-seed-r7-robot-interface: 0.2.0-2
- ros-kinetic-seed-r7-typef-moveit-config: 0.2.0-2
- ros-kinetic-vrx-gazebo: 1.2.4-1
Updated Packages [73]:
- ros-kinetic-costmap-cspace: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-dynamixel-sdk: 3.7.11-1 -> 3.7.21-1
- ros-kinetic-h264-video-encoder: 1.1.3-1 -> 1.1.4-1
- ros-kinetic-ibeo-core: 2.0.2-0 -> 2.0.2-1
- ros-kinetic-ibeo-lux: 2.0.1-0 -> 2.0.1-1
- ros-kinetic-indoor-localization: 0.1.0-1 -> 1.0.0-1
- ros-kinetic-joystick-interrupt: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-libmavconn: 0.32.1-1 -> 0.32.2-1
- ros-kinetic-map-organizer: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-mapviz: 1.1.1-1 -> 1.2.0-1
- ros-kinetic-mapviz-plugins: 1.1.1-1 -> 1.2.0-1
- ros-kinetic-marti-data-structures: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-mavlink: 2019.8.8-1 -> 2019.9.9-1
- ros-kinetic-mavros: 0.32.1-1 -> 0.32.2-1
- ros-kinetic-mavros-extras: 0.32.1-1 -> 0.32.2-1
- ros-kinetic-mavros-msgs: 0.32.1-1 -> 0.32.2-1
- ros-kinetic-multires-image: 1.1.1-1 -> 1.2.0-1
- ros-kinetic-neonavigation: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-neonavigation-common: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-neonavigation-launch: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-novatel-gps-driver: 3.8.0-1 -> 3.9.0-1
- ros-kinetic-novatel-gps-msgs: 3.8.0-1 -> 3.9.0-1
- ros-kinetic-obj-to-pointcloud: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-pilz-control: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-pilz-extensions: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-pilz-industrial-motion: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-pilz-industrial-motion-testutils: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-pilz-msgs: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-pilz-robot-programming: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-pilz-robots: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-pilz-testutils: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-pilz-trajectory-generation: 0.3.8-0 -> 0.3.9-1
- ros-kinetic-planner-cspace: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-prbt-gazebo: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-prbt-hardware-support: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-prbt-ikfast-manipulator-plugin: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-prbt-moveit-config: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-prbt-support: 0.4.9-1 -> 0.4.10-1
- ros-kinetic-robot-state-publisher: 1.13.6-0 -> 1.13.7-1
- ros-kinetic-safety-limiter: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-seed-smartactuator-sdk: 0.0.3-1 -> 0.0.4-1
- ros-kinetic-swri-console-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-dbw-interface: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-geometry-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-image-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-math-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-nodelet: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-opencv-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-prefix-tools: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-roscpp: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-rospy: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-route-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-serial-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-string-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-system-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-transform-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-swri-yaml-util: 2.9.0-1 -> 2.10.0-1
- ros-kinetic-test-mavros: 0.32.1-1 -> 0.32.2-1
- ros-kinetic-tile-map: 1.1.1-1 -> 1.2.0-1
- ros-kinetic-toposens: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-description: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-driver: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-markers: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-msgs: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-pointcloud: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-toposens-sync: 1.2.2-1 -> 1.2.3-1
- ros-kinetic-track-odometry: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-trajectory-tracker: 0.4.2-1 -> 0.4.3-1
- ros-kinetic-usv-gazebo-plugins: 1.2.0-1 -> 1.2.4-1
- ros-kinetic-wamv-description: 1.2.0-1 -> 1.2.4-1
- ros-kinetic-wamv-gazebo: 1.2.0-1 -> 1.2.4-1
- ros-kinetic-wave-gazebo: 1.2.0-1 -> 1.2.4-1
- ros-kinetic-wave-gazebo-plugins: 1.2.0-1 -> 1.2.4-1
Removed Packages [0]:
- AWS RoboMaker
- Adi Singh
- Alexander Gutenkunst
- Atsushi Watanabe
- Carlos Aguero
- Chris Lalancette
- Elcin Erdogan
- G.A. vd. Hoorn (TU Delft Robotics Institute)
- Kris Kozak
- Marc Alban
- Marco Steinbrink
- P. J. Reed
- Pyo
- Rhys Mainwaring
- Vladimir Ermakov
- Yasuto Shiigi
- aaronpb
- hi.kondo
