We’re happy to announce 20 new packages and 45 updated packages for Kinetic. Thank you to everyone who helped make this possible, including maintainers and contributors. Full details are below.
Package Updates for kinetic
Added Packages [20]:
- ros-kinetic-aws-common: 1.0.0-6
- ros-kinetic-aws-ros1-common: 1.0.0-0
- ros-kinetic-behaviortree-cpp: 2.2.0-0
- ros-kinetic-cloudwatch-logger: 1.0.0-0
- ros-kinetic-cloudwatch-logs-common: 1.0.0-0
- ros-kinetic-cloudwatch-metrics-collector: 1.0.0-1
- ros-kinetic-cloudwatch-metrics-common: 1.0.0-0
- ros-kinetic-h264-encoder-core: 1.0.0-1
- ros-kinetic-h264-video-encoder: 1.0.0-0
- ros-kinetic-health-metric-collector: 1.0.0-1
- ros-kinetic-kinesis-manager: 1.0.0-2
- ros-kinetic-kinesis-video-msgs: 1.0.0-1
- ros-kinetic-kinesis-video-streamer: 1.0.0-1
- ros-kinetic-lex-common-msgs: 1.0.0-1
- ros-kinetic-lex-node: 1.0.0-1
- ros-kinetic-recordit: 1.0.0-2
- ros-kinetic-robot-recorder: 1.0.0-2
- ros-kinetic-ros-monitoring-msgs: 1.0.0-3
- ros-kinetic-rviz-recorder-buttons: 1.0.0-2
- ros-kinetic-tts: 1.0.0-1
Updated Packages [45]:
- ros-kinetic-adi-driver: 1.0.2-0 -> 1.0.3-0
- ros-kinetic-franka-control: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-description: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-example-controllers: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-gripper: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-hw: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-msgs: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-ros: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-franka-visualization: 0.6.0-0 -> 0.6.0-1
- ros-kinetic-geometry2: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-ibeo-core: 2.0.0-0 -> 2.0.1-0
- ros-kinetic-libmavconn: 0.26.3-0 -> 0.27.0-0
- ros-kinetic-mapviz: 0.2.6-0 -> 0.3.0-0
- ros-kinetic-mapviz-plugins: 0.2.6-0 -> 0.3.0-0
- ros-kinetic-mavlink: 2018.10.10-0 -> 2018.11.11-0
- ros-kinetic-mavros: 0.26.3-0 -> 0.27.0-0
- ros-kinetic-mavros-extras: 0.26.3-0 -> 0.27.0-0
- ros-kinetic-mavros-msgs: 0.26.3-0 -> 0.27.0-0
- ros-kinetic-mbf-abstract-core: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-abstract-nav: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-costmap-core: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-costmap-nav: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-msgs: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-simple-nav: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-mbf-utility: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-move-base-flex: 0.2.2-0 -> 0.2.3-0
- ros-kinetic-moveit-visual-tools: 3.4.0-0 -> 3.4.1-0
- ros-kinetic-multires-image: 0.2.6-0 -> 0.3.0-0
- ros-kinetic-nerian-stereo: 3.0.2-0 -> 3.1.1-0
- ros-kinetic-pacmod3: 1.1.1-0 -> 1.2.0-0
- ros-kinetic-panda-moveit-config: 0.6.0-0 -> 0.7.0-1
- ros-kinetic-plotjuggler: 1.8.4-0 -> 1.9.0-0
- ros-kinetic-rosfmt: 5.2.2-0 -> 6.0.0-0
- ros-kinetic-test-mavros: 0.26.3-0 -> 0.27.0-0
- ros-kinetic-tf2: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-bullet: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-eigen: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-geometry-msgs: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-kdl: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-msgs: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-py: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-ros: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-sensor-msgs: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tf2-tools: 0.5.19-0 -> 0.5.20-0
- ros-kinetic-tile-map: 0.2.6-0 -> 0.3.0-0
Removed Packages [0]:
- AWS RoboMaker
- AutonomouStuff Software Team
- Dave Coleman
- Davide Faconti
- Franka Emika GmbH
- Jonathan Hechtbauer
- Jorge Santos
- Koji Terada
- Konstantin Schauwecker
- Marc Alban
- Max Schwarz
- Michele Colledanchise
- Mike Lautman
- Sebastian Pütz
- Tokyo Opensource Robotics Kyokai (TORK) Developer Team
- Tully Foote
- Vincent Rabaud
- Vladimir Ermakov
- shi
