We’re happy to announce 25 new packages and 57 updated packages for Kinetic.
Please see the full details below. And thank you to all the maintainers and contributors who have helped make these releases possible!
Package Updates for kinetic
Added Packages [25]:
- ros-kinetic-exotica-val-description: 1.0.0-2
- ros-kinetic-flexbe-behavior-engine: 1.1.1-0
- ros-kinetic-flexbe-core: 1.1.1-0
- ros-kinetic-flexbe-input: 1.1.1-0
- ros-kinetic-flexbe-mirror: 1.1.1-0
- ros-kinetic-flexbe-msgs: 1.1.1-0
- ros-kinetic-flexbe-onboard: 1.1.1-0
- ros-kinetic-flexbe-states: 1.1.1-0
- ros-kinetic-flexbe-testing: 1.1.1-0
- ros-kinetic-flexbe-widget: 1.1.1-0
- ros-kinetic-flir-boson-usb: 1.0.0-0
- ros-kinetic-hebi-cpp-api: 2.0.1-1
- ros-kinetic-iirob-filters: 0.8.1-3
- ros-kinetic-ipr-extern: 0.8.8-0
- ros-kinetic-libmodbus: 0.8.8-0
- ros-kinetic-libreflexxestype2: 0.8.8-0
- ros-kinetic-melfa-description: 0.0.3-0
- ros-kinetic-melfa-driver: 0.0.3-0
- ros-kinetic-melfa-robot: 0.0.3-0
- ros-kinetic-pal-hardware-interfaces: 0.0.3-0
- ros-kinetic-pheeno-ros-description: 0.1.0-0
- ros-kinetic-ros-reflexxes: 0.8.8-0
- ros-kinetic-rv4fl-moveit-config: 0.0.3-0
- ros-kinetic-rv7fl-moveit-config: 0.0.3-0
- ros-kinetic-urdf-test: 1.0.4-0
Updated Packages [57]:
- ros-kinetic-behaviortree-cpp: 2.4.1-0 -> 2.4.4-0
- ros-kinetic-catch-ros: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-costmap-cspace-msgs: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-dataspeed-can: 1.0.11-0 -> 1.0.12-0
- ros-kinetic-dataspeed-can-msg-filters: 1.0.11-0 -> 1.0.12-0
- ros-kinetic-dataspeed-can-tools: 1.0.11-0 -> 1.0.12-0
- ros-kinetic-dataspeed-can-usb: 1.0.11-0 -> 1.0.12-0
- ros-kinetic-default-cfg-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-dockeros: 1.0.2-0 -> 1.0.3-0
- ros-kinetic-euslisp: 9.25.0-0 -> 9.26.0-0
- ros-kinetic-map-organizer-msgs: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-marti-data-structures: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-master-discovery-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-master-sync-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-mavlink: 2018.11.11-0 -> 2018.12.12-0
- ros-kinetic-mcl-3dl: 0.1.3-0 -> 0.1.4-0
- ros-kinetic-multimaster-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-multimaster-msgs-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-neonavigation-msgs: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-nmea-navsat-driver: 0.5.0-0 -> 0.5.1-0
- ros-kinetic-node-manager-fkie: 0.8.4-0 -> 0.8.9-0
- ros-kinetic-ocean-battery-driver: 1.1.6-0 -> 1.1.7-0
- ros-kinetic-pacmod-game-control: 2.2.0-0 -> 2.3.0-0
- ros-kinetic-planner-cspace-msgs: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-power-monitor: 1.1.6-0 -> 1.1.7-0
- ros-kinetic-pr2-power-board: 1.1.6-0 -> 1.1.7-0
- ros-kinetic-pr2-power-drivers: 1.1.6-0 -> 1.1.7-0
- ros-kinetic-rc-genicam-api: 2.0.0-0 -> 2.0.2-0
- ros-kinetic-rosapi: 0.9.0-0 -> 0.10.1-0
- ros-kinetic-rosbridge-library: 0.9.0-0 -> 0.10.1-0
- ros-kinetic-rosbridge-server: 0.9.0-0 -> 0.10.1-0
- ros-kinetic-rosbridge-suite: 0.9.0-0 -> 0.10.1-0
- ros-kinetic-rqt-multiplot: 0.0.8-0 -> 0.0.10-0
- ros-kinetic-rr-openrover-basic: 0.6.0-0 -> 0.6.1-0
- ros-kinetic-swri-console-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-dbw-interface: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-geometry-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-image-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-math-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-nodelet: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-opencv-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-prefix-tools: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-roscpp: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-rospy: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-route-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-serial-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-string-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-system-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-transform-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-swri-yaml-util: 2.7.0-0 -> 2.7.2-0
- ros-kinetic-trajectory-tracker-msgs: 0.2.0-0 -> 0.3.0-0
- ros-kinetic-ubiquity-motor: 0.7.0-0 -> 0.8.0-0
- ros-kinetic-uuv-cpc-sensor: 0.3.0-0 -> 0.3.1-0
- ros-kinetic-uuv-plume-msgs: 0.3.0-0 -> 0.3.1-0
- ros-kinetic-uuv-plume-simulator: 0.3.0-0 -> 0.3.1-0
- ros-kinetic-video-stream-opencv: 1.1.4-0 -> 1.1.5-0
- ros-kinetic-visualstates: 0.2.1-1 -> 0.2.2-0
Removed Packages [0]:
- Alexander Tiderko
- Atsushi Watanabe
- Christian Henkel
- Daniel Zumkeller
- Denis Štogl
- Ed Venator
- Felix Ruess
- Hilario Tome
- Jack Kilian
- Kei Okada
- Kevin Hallenbeck
- Kris Kozak
- Marc Alban
- Matthew Tesch
- Max Schwarz
- Michele Colledanchise
- Micho Radovnikovich
- Musa Morena Marcusso Manhaes
- Okan Aşık
- P. J. Reed
- Philipp Schillinger
- ROS Orphaned Package Maintainers
- Ralf Kaestner
- Rohan Agrawal
- Russell Toris
- Sammy Pfeiffer
- Tokyo Opensource Robotics Kyokai (TORK) Developer Team
- Tokyo Opensource Robotics Kyokai(TORK) Developer Team
- Vladimir Ermakov
- Wolfgang Merkt
- Zahi Kakish
- davidfernandez
- stogl
