We’re happy to announce 7 new packages and 44 updated packages for Kinetic.
Thank you to all the maintainers and contributors who have helped make these updates possible. Full details are below.
Package Updates for kinetic
Added Packages [7]:
- ros-kinetic-dual-quaternions: 0.3.2-1
- ros-kinetic-leo-description: 0.3.0-1
- ros-kinetic-leo-viz: 0.2.0-1
- ros-kinetic-marti-dbw-msgs: 0.9.0-1
- ros-kinetic-rosbag-snapshot-msgs: 1.0.0-1
- ros-kinetic-rr-openrover-stack: 1.0.1-1
- ros-kinetic-rr-rover-zero-driver: 1.0.1-1
Updated Packages [44]:
- ros-kinetic-abb-driver: 1.3.1-1 -> 1.4.0-1
- ros-kinetic-behaviortree-cpp-v3: 3.5.0-2 -> 3.5.1-1
- ros-kinetic-costmap-cspace: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-flexbe-behavior-engine: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-core: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-input: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-mirror: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-msgs: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-onboard: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-states: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-testing: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-flexbe-widget: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-graph-msgs: 0.1.0-0 -> 0.1.0-1
- ros-kinetic-joystick-interrupt: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-jskeus: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-librealsense2: 2.33.1-2 -> 2.35.2-2
- ros-kinetic-map-organizer: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-marti-can-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-common-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-nav-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-perception-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-sensor-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-status-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-marti-visualization-msgs: 0.8.0-0 -> 0.9.0-1
- ros-kinetic-mqtt-bridge: 0.1.6-0 -> 0.1.7-2
- ros-kinetic-neonavigation: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-neonavigation-common: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-neonavigation-launch: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-obj-to-pointcloud: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-planner-cspace: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-realsense2-camera: 2.2.13-1 -> 2.2.14-1
- ros-kinetic-realsense2-description: 2.2.13-1 -> 2.2.14-1
- ros-kinetic-rqt-reconfigure: 0.5.1-1 -> 0.5.3-1
- ros-kinetic-rr-control-input-manager: 1.0.0-3 -> 1.0.1-1
- ros-kinetic-rr-openrover-description: 1.0.0-3 -> 1.0.1-1
- ros-kinetic-rr-openrover-driver: 1.0.0-3 -> 1.0.1-1
- ros-kinetic-rr-openrover-driver-msgs: 1.0.0-3 -> 1.0.1-1
- ros-kinetic-rr-openrover-simulation: 1.0.0-3 -> 1.0.1-1
- ros-kinetic-safety-limiter: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-sick-safetyscanners: 1.0.4-1 -> 1.0.5-1
- ros-kinetic-soem: 1.4.0-1 -> 1.4.1000-1
- ros-kinetic-track-odometry: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-trajectory-tracker: 0.8.7-1 -> 0.8.8-1
- ros-kinetic-urg-stamped: 0.0.5-1 -> 0.0.6-1
Removed Packages [0]:
- Atsushi Watanabe
- Dave Coleman
- David V. Lu!!
- Davide Faconti
- Edmond DuPont
- Junya Hayashi
- Kei Okada
- Lennart Puck
- Levi Armstrong (Southwest Research Institute)
- Marc Alban
- Matthew Bries
- Matthias Gruhler
- Nicholas Padilla
- Nick Padilla
- Philipp Schillinger
- Scott K Logan
- Sergey Dorodnicov
- achille
- fictionlab
- nickp
