We’re happy to announce the release of 41 new packages and 114 updated packages into Kinetic. These packages are brought to you by more than two dozen maintainers and many more contributors.
Thank you to everyone who has helped make this sync possible. Full details are below.
Package Updates for kinetic
Added Packages [41]:
- ros-kinetic-codec-image-transport: 0.0.3-0
- ros-kinetic-desistek-saga-control: 0.3.2-0
- ros-kinetic-desistek-saga-description: 0.3.2-0
- ros-kinetic-desistek-saga-gazebo: 0.3.2-0
- ros-kinetic-dsr-description: 0.9.6-1
- ros-kinetic-dsr-example-py: 0.9.6-1
- ros-kinetic-dsr-gazebo: 0.9.6-1
- ros-kinetic-dsr-launcher: 0.9.6-1
- ros-kinetic-dsr-msgs: 0.9.6-1
- ros-kinetic-eca-a9-control: 0.1.6-0
- ros-kinetic-eca-a9-description: 0.1.6-0
- ros-kinetic-eca-a9-gazebo: 0.1.6-0
- ros-kinetic-khi-duaro-description: 1.1.0-1
- ros-kinetic-khi-duaro-gazebo: 1.1.0-1
- ros-kinetic-khi-duaro-ikfast-plugin: 1.1.0-1
- ros-kinetic-khi-duaro-moveit-config: 1.1.0-1
- ros-kinetic-khi-rs-description: 1.1.0-1
- ros-kinetic-khi-rs-gazebo: 1.1.0-1
- ros-kinetic-khi-rs-ikfast-plugin: 1.1.0-1
- ros-kinetic-khi-rs007l-moveit-config: 1.1.0-1
- ros-kinetic-khi-rs007n-moveit-config: 1.1.0-1
- ros-kinetic-khi-rs080n-moveit-config: 1.1.0-1
- ros-kinetic-lauv-control: 0.1.6-0
- ros-kinetic-lauv-description: 0.1.6-0
- ros-kinetic-lauv-gazebo: 0.1.6-0
- ros-kinetic-moveit-config-m0609: 0.9.6-1
- ros-kinetic-moveit-config-m0617: 0.9.6-1
- ros-kinetic-moveit-config-m1013: 0.9.6-1
- ros-kinetic-moveit-config-m1509: 0.9.6-1
- ros-kinetic-mrpt-graphslam-2d: 0.1.9-0
- ros-kinetic-quaternion-operation: 0.0.1-1
- ros-kinetic-rexrov2-control: 0.1.3-0
- ros-kinetic-rexrov2-description: 0.1.3-0
- ros-kinetic-rexrov2-gazebo: 0.1.3-0
- ros-kinetic-rosserial-leonardo-cmake: 0.1.4-0
- ros-kinetic-universal-robots: 1.2.5-0
- ros-kinetic-ur-e-description: 1.2.5-0
- ros-kinetic-ur-e-gazebo: 1.2.5-0
- ros-kinetic-ur10-e-moveit-config: 1.2.5-0
- ros-kinetic-ur3-e-moveit-config: 1.2.5-0
- ros-kinetic-ur5-e-moveit-config: 1.2.5-0
Updated Packages [114]:
- ros-kinetic-cob-actions: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-base-controller-utils: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-base-velocity-smoother: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-bringup: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-calibration-data: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-cartesian-controller: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-collision-velocity-filter: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-command-gui: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-command-tools: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-common: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-control: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-control-mode-adapter: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-control-msgs: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-dashboard: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-default-env-config: 0.6.7-0 -> 0.6.8-0
- ros-kinetic-cob-default-robot-behavior: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-default-robot-config: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-description: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-environments: 0.6.7-0 -> 0.6.8-0
- ros-kinetic-cob-footprint-observer: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-frame-tracker: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-hardware-config: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-helper-tools: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-interactive-teleop: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-model-identifier: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-monitoring: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-moveit-config: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-msgs: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-obstacle-distance: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-omni-drive-controller: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-robots: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-script-server: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-srvs: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-supported-robots: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-teleop: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-cob-trajectory-controller: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-tricycle-controller: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-cob-twist-controller: 0.7.3-0 -> 0.7.4-0
- ros-kinetic-flexbe-behavior-engine: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-core: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-input: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-mirror: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-msgs: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-onboard: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-states: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-testing: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-flexbe-widget: 1.1.1-0 -> 1.1.2-0
- ros-kinetic-generic-throttle: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-heron-description: 0.3.0-0 -> 0.3.1-0
- ros-kinetic-heron-msgs: 0.3.0-0 -> 0.3.1-0
- ros-kinetic-husky-base: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-bringup: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-control: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-description: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-desktop: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-gazebo: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-msgs: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-navigation: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-robot: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-simulator: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-husky-viz: 0.3.2-0 -> 0.3.3-0
- ros-kinetic-industrial-robot-status-controller: 0.1.0-0 -> 0.1.1-0
- ros-kinetic-industrial-robot-status-interface: 0.1.0-0 -> 0.1.1-0
- ros-kinetic-jackal-control: 0.6.1-0 -> 0.6.2-0
- ros-kinetic-jackal-description: 0.6.1-0 -> 0.6.2-0
- ros-kinetic-jackal-msgs: 0.6.1-0 -> 0.6.2-0
- ros-kinetic-jackal-navigation: 0.6.1-0 -> 0.6.2-0
- ros-kinetic-jackal-tutorials: 0.6.1-0 -> 0.6.2-0
- ros-kinetic-khi-robot-msgs: 1.0.0-0 -> 1.1.0-1
- ros-kinetic-libmongocxx-ros: 0.4.2-0 -> 0.4.4-2
- ros-kinetic-mavlink: 2019.3.3-0 -> 2019.4.4-0
- ros-kinetic-ml-classifiers: 0.4.1-0 -> 1.0.1-1
- ros-kinetic-mongodb-log: 0.4.2-0 -> 0.4.4-2
- ros-kinetic-mongodb-store: 0.4.2-0 -> 0.4.4-2
- ros-kinetic-mongodb-store-msgs: 0.4.2-0 -> 0.4.4-2
- ros-kinetic-mrpt-ekf-slam-2d: 0.1.6-0 -> 0.1.9-0
- ros-kinetic-mrpt-ekf-slam-3d: 0.1.6-0 -> 0.1.9-0
- ros-kinetic-mrpt-icp-slam-2d: 0.1.6-0 -> 0.1.9-0
- ros-kinetic-mrpt-local-obstacles: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-localization: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-map: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-navigation: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-rawlog: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-rbpf-slam: 0.1.6-0 -> 0.1.9-0
- ros-kinetic-mrpt-reactivenav2d: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mrpt-slam: 0.1.6-0 -> 0.1.9-0
- ros-kinetic-mrpt-tutorials: 0.1.23-0 -> 0.1.24-0
- ros-kinetic-mvsim: 0.2.0-0 -> 0.2.1-0
- ros-kinetic-omron-os32c-driver: 0.1.2-0 -> 0.1.3-0
- ros-kinetic-opencv-apps: 2.0.0-0 -> 2.0.1-1
- ros-kinetic-raw-description: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-ros-type-introspection: 1.3.1-0 -> 1.3.2-0
- ros-kinetic-service-tools: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-towr: 1.4.0-0 -> 1.4.1-0
- ros-kinetic-towr-ros: 1.4.0-0 -> 1.4.1-0
- ros-kinetic-ubiquity-motor: 0.8.0-0 -> 0.9.0-0
- ros-kinetic-universal-robot: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-bringup: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-description: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-driver: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-gazebo: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-kinematics: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur-msgs: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur10-moveit-config: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur3-moveit-config: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-ur5-moveit-config: 1.2.1-0 -> 1.2.5-0
- ros-kinetic-visp: 3.1.0-2 -> 3.2.0-3
- ros-kinetic-xpp: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-examples: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-hyq: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-msgs: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-quadrotor: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-states: 1.0.8-0 -> 1.0.10-0
- ros-kinetic-xpp-vis: 1.0.8-0 -> 1.0.10-0
Removed Packages [0]:
- Alexander Bubeck
- Alexander W. Winkler
- Benjamin Maidel
- Davide Faconti
- Doosan Robotics
- Emre Ege
- Fabien Spindler
- Felipe Garcia Lopez
- Felix Messmer
- G.A. vd. Hoorn
- G.A. vd. Hoorn (TU Delft Robotics Institute)
- Jannik Abbenseth
- Jose Luis
- Jose Luis Blanco Claraco
- Jose-Luis Blanco-Claraco
- Kei Okada
- Marc Hanheide
- Markus Bader
- Masaya Kataoka
- Mike Purvis
- Musa Morena Marcusso Manhaes
- Nick Hawes
- Nikos Koukis
- Paul Bovbel
- Philipp Schillinger
- Rein Appeldoorn
- Richard Bormann
- Rohan Agrawal
- Thibault Pelletier
- Vladimir Ermakov
- Vladislav Tananaev
- Yoshito Okada
- jinhyuk.gong
- matsui_hiro
- nakamichi_d
