We’re happy to announce 6 new packages and 177 update packages for Kinetic. There is one known regression which removes 3 packages in this sync. The maintainer is looking at the regression and we expect it to be restored soon.
Thank you to everyone who has helped make these packages available to the community, including the maintainers and contributors!
Package Updates for kinetic
Added Packages [6]:
- ros-kinetic-collada-urdf-jsk-patch: 2.1.12-1
- ros-kinetic-flir-camera-driver: 0.1.3-0
- ros-kinetic-qb-chain-controllers: 2.1.1-1
- ros-kinetic-rc-pick-client: 2.6.2-1
- ros-kinetic-rc-visard: 2.6.2-1
- ros-kinetic-rostwitter: 2.1.12-1
Updated Packages [177]:
- ros-kinetic-abseil-cpp: 0.2.3-0 -> 0.4.1-1
- ros-kinetic-actionlib-enhanced: 0.0.4-1 -> 0.0.6-1
- ros-kinetic-agni-tf-tools: 0.1.1-0 -> 0.1.2-1
- ros-kinetic-assimp-devel: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-bayesian-belief-networks: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-catkin: 0.7.14-0 -> 0.7.18-1
- ros-kinetic-cob-base-controller-utils: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-base-drive-chain: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-base-velocity-smoother: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-bms-driver: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-camera-sensors: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-canopen-motor: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-cartesian-controller: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-collision-velocity-filter: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-command-gui: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-command-tools: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-control: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-control-mode-adapter: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-control-msgs: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-dashboard: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-driver: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-elmo-homing: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-footprint-observer: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-frame-tracker: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-generic-can: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-helper-tools: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-interactive-teleop: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-light: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-mimic: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-model-identifier: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-monitoring: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-obstacle-distance: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-omni-drive-controller: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-phidget-em-state: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-phidget-power-state: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-phidgets: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-relayboard: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-scan-unifier: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-script-server: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-sick-lms1xx: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-sick-s300: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-sound: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-teleop: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-cob-trajectory-controller: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-tricycle-controller: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-twist-controller: 0.7.5-1 -> 0.7.6-1
- ros-kinetic-cob-undercarriage-ctrl: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-utilities: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-cob-voltage-control: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-downward: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-eigen-typekit: 2.9.2-1 -> 2.9.3-1
- ros-kinetic-euslisp: 9.26.0-0 -> 9.26.0-1
- ros-kinetic-fcl-catkin: 0.5.96-0 -> 0.5.98-1
- ros-kinetic-ff: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-ffha: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-flexbe-behavior-engine: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-core: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-input: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-mirror: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-msgs: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-onboard: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-states: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-testing: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-flexbe-widget: 1.1.2-0 -> 1.2.1-1
- ros-kinetic-gazebo-dev: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-gazebo-msgs: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-gazebo-plugins: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-gazebo-ros: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-gazebo-ros-control: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-gazebo-ros-pkgs: 2.5.18-1 -> 2.5.19-1
- ros-kinetic-generic-throttle: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-jsk-3rdparty: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-jskeus: 1.2.1-0 -> 1.2.1-1
- ros-kinetic-julius: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-julius-ros: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-kdl-typekit: 2.9.2-1 -> 2.9.3-1
- ros-kinetic-khi-duaro-description: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-duaro-gazebo: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-duaro-ikfast-plugin: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-duaro-moveit-config: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-robot: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-robot-bringup: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-robot-control: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-robot-msgs: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs-description: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs-gazebo: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs-ikfast-plugin: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs007l-moveit-config: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs007n-moveit-config: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-khi-rs080n-moveit-config: 1.1.1-1 -> 1.1.2-1
- ros-kinetic-laser-scan-densifier: 0.6.13-0 -> 0.6.14-1
- ros-kinetic-libcmt: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-libmavconn: 0.30.0-1 -> 0.31.0-1
- ros-kinetic-libsiftfast: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-lpg-planner: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-mavlink: 2019.5.20-1 -> 2019.6.7-1
- ros-kinetic-mavros: 0.30.0-1 -> 0.31.0-1
- ros-kinetic-mavros-extras: 0.30.0-1 -> 0.31.0-1
- ros-kinetic-mavros-msgs: 0.30.0-1 -> 0.31.0-1
- ros-kinetic-mini-maxwell: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-mk: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-nlopt: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-novatel-gps-driver: 3.7.0-0 -> 3.8.0-1
- ros-kinetic-novatel-gps-msgs: 3.7.0-0 -> 3.8.0-1
- ros-kinetic-ocl: 2.9.0-1 -> 2.9.1-3
- ros-kinetic-opt-camera: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-panda-moveit-config: 0.7.0-1 -> 0.7.2-1
- ros-kinetic-pgm-learner: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-qb-chain: 2.0.0-0 -> 2.1.1-1
- ros-kinetic-qb-chain-control: 2.0.0-0 -> 2.1.1-1
- ros-kinetic-qb-chain-description: 2.0.0-0 -> 2.1.1-1
- ros-kinetic-qb-device: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-bringup: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-control: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-description: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-driver: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-hardware-interface: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-msgs: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-srvs: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-device-utils: 2.0.1-0 -> 2.1.0-1
- ros-kinetic-qb-move: 2.0.0-0 -> 2.1.2-1
- ros-kinetic-qb-move-control: 2.0.0-0 -> 2.1.2-1
- ros-kinetic-qb-move-description: 2.0.0-0 -> 2.1.2-1
- ros-kinetic-qb-move-hardware-interface: 2.0.0-0 -> 2.1.2-1
- ros-kinetic-quaternion-operation: 0.0.1-2 -> 0.0.3-1
- ros-kinetic-rc-hand-eye-calibration-client: 2.6.1-1 -> 2.6.2-1
- ros-kinetic-rc-tagdetect-client: 2.6.1-1 -> 2.6.2-1
- ros-kinetic-rc-visard-description: 2.6.1-1 -> 2.6.2-1
- ros-kinetic-rc-visard-driver: 2.6.1-1 -> 2.6.2-1
- ros-kinetic-respeaker-ros: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-ros: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-ros-speech-recognition: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-rosbash: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rosboost-cfg: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rosbuild: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rosclean: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-roscreate: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-roslang: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-roslib: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rosmake: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rospack: 2.4.4-0 -> 2.4.5-1
- ros-kinetic-rospatlite: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-rosping: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-rosunit: 1.14.4-0 -> 1.14.6-1
- ros-kinetic-rtt-geometry: 2.9.2-1 -> 2.9.3-1
- ros-kinetic-service-tools: 0.6.11-0 -> 0.6.12-1
- ros-kinetic-sick-scan: 0.0.16-0 -> 1.3.21-0
- ros-kinetic-slic: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-test-mavros: 0.30.0-1 -> 0.31.0-1
- ros-kinetic-uuv-assistants: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-auv-control-allocator: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-control-cascaded-pid: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-control-msgs: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-control-utils: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-descriptions: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-gazebo: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-gazebo-plugins: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-gazebo-ros-plugins: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-gazebo-ros-plugins-msgs: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-gazebo-worlds: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-sensor-ros-plugins: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-sensor-ros-plugins-msgs: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-simulator: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-teleop: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-thruster-manager: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-trajectory-control: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-world-plugins: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-world-ros-plugins: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-uuv-world-ros-plugins-msgs: 0.6.10-0 -> 0.6.12-0
- ros-kinetic-vision-visp: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-visp-auto-tracker: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-visp-bridge: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-visp-camera-calibration: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-visp-hand2eye-calibration: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-visp-tracker: 0.10.0-0 -> 0.11.0-1
- ros-kinetic-voice-text: 2.1.11-0 -> 2.1.12-1
- ros-kinetic-web-video-server: 0.2.0-0 -> 0.2.1-1
Removed Packages [3]:
- ros-kinetic-plotjuggler
- ros-kinetic-ros-type-introspection
- ros-kinetic-topic-switch
- Alessandro Tondo
- Alexander Bubeck
- Benjamin Maidel
- Dirk Thomas
- Fabien Spindler
- Fabrice Poirier
- Felipe Garcia Lopez
- Felix Messmer
- Felix Ruess
- Florian Weisshardt
- Hitoshi Kamada
- John Hsu
- Jose Luis Rivero
- Joshua Hampp
- Kei Okada
- Luiz Ricardo Douat
- Masaya Kataoka
- Matthias Gruhler
- Michael Hosmar
- Michael Lehning
- Mike Lautman
- Monika Florek-Jasinska
- Musa Morena Marcusso Manhaes
- Noda Shintaro
- Orocos Developers
- P. J. Reed
- Philipp Schillinger
- Richard Bormann
- Robert Haschke
- Russell Toris
- Ryohei Ueda
- Takuya Nakaoka
- Vladimir Ermakov
- Wolfgang Merkt
- Yohei Kakiuchi
- Yuki Furuta
- Yuto Inagaki
- dfaconti
- k-okada
- matsui_hiro
- nakamichi_d
