We’re happy to announce 34 new packages and 60 updated packages for Kinetic Kame.
Thank you to all the maintainers and contributors who have helped make these new packages available to the community!
Full details are below.
Package Updates for kinetic
Added Packages [34]:
- ros-kinetic-ainstein-radar: 1.0.2-1
- ros-kinetic-ainstein-radar-drivers: 1.0.2-1
- ros-kinetic-ainstein-radar-filters: 1.0.2-1
- ros-kinetic-ainstein-radar-gazebo-plugins: 1.0.2-1
- ros-kinetic-ainstein-radar-msgs: 1.0.2-1
- ros-kinetic-ainstein-radar-rviz-plugins: 1.0.2-1
- ros-kinetic-fanuc-cr35ia-support: 0.5.0-1
- ros-kinetic-fanuc-cr7ia-support: 0.5.0-1
- ros-kinetic-fanuc-driver: 0.5.0-1
- ros-kinetic-fanuc-lrmate200i-support: 0.5.0-1
- ros-kinetic-fanuc-lrmate200ib-support: 0.5.0-1
- ros-kinetic-fanuc-lrmate200ic-support: 0.5.0-1
- ros-kinetic-fanuc-m10ia-support: 0.5.0-1
- ros-kinetic-fanuc-m16ib-support: 0.5.0-1
- ros-kinetic-fanuc-m20ia-support: 0.5.0-1
- ros-kinetic-fanuc-m20ib-support: 0.5.0-1
- ros-kinetic-fanuc-m430ia-support: 0.5.0-1
- ros-kinetic-fanuc-m6ib-support: 0.5.0-1
- ros-kinetic-fanuc-m710ic-support: 0.5.0-1
- ros-kinetic-fanuc-m900ia-support: 0.5.0-1
- ros-kinetic-fanuc-m900ib-support: 0.5.0-1
- ros-kinetic-fanuc-r1000ia-support: 0.5.0-1
- ros-kinetic-fanuc-resources: 0.5.0-1
- ros-kinetic-hebi-description: 0.1.0-1
- ros-kinetic-iiwa-control: 1.4.1-1
- ros-kinetic-iiwa-description: 1.4.1-1
- ros-kinetic-iiwa-gazebo: 1.4.1-1
- ros-kinetic-iiwa-hw: 1.4.1-1
- ros-kinetic-iiwa-moveit: 1.4.1-1
- ros-kinetic-iiwa-msgs: 1.4.1-1
- ros-kinetic-iiwa-ros: 1.4.1-1
- ros-kinetic-odom-frame-publisher: 0.0.1-1
- ros-kinetic-rxros: 0.1.0-1
- ros-kinetic-rxros-tf: 0.1.0-1
Updated Packages [60]:
- ros-kinetic-abb: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-driver: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb2400-moveit-config: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb2400-moveit-plugins: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb2400-support: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb4400-support: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb5400-support: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb6600-support: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb6640-moveit-config: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-irb6640-support: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-abb-resources: 1.3.0-1 -> 1.3.1-1
- ros-kinetic-fcl-catkin: 0.5.98-1 -> 0.5.99-2
- ros-kinetic-flexbe-behavior-engine: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-core: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-input: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-mirror: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-msgs: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-onboard: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-states: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-testing: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-flexbe-widget: 1.2.1-1 -> 1.2.2-1
- ros-kinetic-industrial-core: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-deprecated: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-msgs: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-robot-client: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-robot-simulator: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-trajectory-filters: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-industrial-utils: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-jog-control: 0.0.1-0 -> 0.0.2-1
- ros-kinetic-jog-controller: 0.0.1-0 -> 0.0.2-1
- ros-kinetic-jog-launch: 0.0.1-0 -> 0.0.2-1
- ros-kinetic-jog-msgs: 0.0.1-0 -> 0.0.2-1
- ros-kinetic-pilz-control: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-pilz-extensions: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-pilz-industrial-motion: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-pilz-industrial-motion-testutils: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-pilz-msgs: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-pilz-robot-programming: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-pilz-robots: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-pilz-testutils: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-pilz-trajectory-generation: 0.3.9-1 -> 0.3.10-1
- ros-kinetic-plotjuggler: 2.3.0-1 -> 2.3.1-2
- ros-kinetic-prbt-gazebo: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-prbt-hardware-support: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-prbt-ikfast-manipulator-plugin: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-prbt-moveit-config: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-prbt-support: 0.4.10-1 -> 0.4.11-1
- ros-kinetic-quaternion-operation: 0.0.3-1 -> 0.0.3-2
- ros-kinetic-rc-common-msgs: 0.2.1-1 -> 0.3.0-1
- ros-kinetic-rc-dynamics-api: 0.8.0-1 -> 0.10.0-1
- ros-kinetic-resource-retriever: 1.12.4-0 -> 1.12.5-1
- ros-kinetic-simple-message: 0.7.0-0 -> 0.7.1-1
- ros-kinetic-soem: 1.3.0-0 -> 1.4.0-1
- ros-kinetic-um6: 1.1.2-0 -> 1.1.3-1
- ros-kinetic-usv-gazebo-plugins: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-vrx-gazebo: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-wamv-description: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-wamv-gazebo: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-wave-gazebo: 1.2.4-1 -> 1.2.5-1
- ros-kinetic-wave-gazebo-plugins: 1.2.4-1 -> 1.2.5-1
Removed Packages [0]:
- Alexander Gutenkunst
- Andrzej Wasowski
- Carlos Aguero
- Chris Lalancette
- Davide Faconti
- Felix Ruess
- G.A. vd. Hoorn (TU Delft Robotics Institute)
- Levi Armstrong (Southwest Research Institute)
- Masaya Kataoka
- Matthew Tesch
- Matthias Gruhler
- Mike Purvis
- Nick Rotella
- Philipp Schillinger
- Rhys Mainwaring
- Salvo Virga
- Shaun Edwards
- Tokyo Opensource Robotics Kyokai (TORK) Developer Team
- Tokyo Opensource Robotics Kyokai(TORK) Developer Team
- Wolfgang Merkt
- masaya kataoka
- nrotella
