We’re happy to announce 12 new and 144 updated packages for Kinetic.
There is one regression of pinocchio due to cmake/pkg-config that’s being actively worked on to be resolved.
Thank you to all the maintainers and contributors who have helped make these packages available!
Details are below.
Package Updates for kinetic
Added Packages [12]:
- ros-kinetic-cob-gazebo-tools: 0.7.3-1
- ros-kinetic-cob-hardware-emulation: 0.7.9-1
- ros-kinetic-leuze-description: 1.0.0-2
- ros-kinetic-leuze-msgs: 1.0.0-2
- ros-kinetic-leuze-phidget-driver: 1.0.0-2
- ros-kinetic-network-autoconfig: 0.1.1-1
- ros-kinetic-robot-indicator: 0.1.3-1
- ros-kinetic-robot-systemd: 0.1.2-1
- ros-kinetic-seed-r7-moveit-config: 0.3.0-1
- ros-kinetic-seed-r7-ros-controller: 0.3.0-1
- ros-kinetic-seed-r7-samples: 0.3.0-1
- ros-kinetic-turtlebot-loadout-kha1: 0.1.0-3
Updated Packages [144]:
- ros-kinetic-ainstein-radar: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-ainstein-radar-drivers: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-ainstein-radar-filters: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-ainstein-radar-gazebo-plugins: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-ainstein-radar-msgs: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-ainstein-radar-rviz-plugins: 1.0.3-1 -> 1.1.0-1
- ros-kinetic-behaviortree-cpp-v3: 3.0.7-0 -> 3.1.0-3
- ros-kinetic-can-msgs: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-canopen-402: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-canopen-chain-node: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-canopen-master: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-canopen-motor-node: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-cloudwatch-logs-common: 1.1.0-2 -> 1.1.2-1
- ros-kinetic-cloudwatch-metrics-common: 1.1.0-2 -> 1.1.2-1
- ros-kinetic-cob-actions: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-base-controller-utils: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-base-drive-chain: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-base-velocity-smoother: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-bms-driver: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-bringup: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-bringup-sim: 0.7.1-2 -> 0.7.3-1
- ros-kinetic-cob-calibration-data: 0.6.12-1 -> 0.6.13-1
- ros-kinetic-cob-camera-sensors: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-canopen-motor: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-cartesian-controller: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-collision-velocity-filter: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-command-gui: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-command-tools: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-common: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-control: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-control-mode-adapter: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-control-msgs: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-dashboard: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-default-robot-behavior: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-default-robot-config: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-description: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-driver: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-elmo-homing: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-extern: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-cob-footprint-observer: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-frame-tracker: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-gazebo: 0.7.1-2 -> 0.7.3-1
- ros-kinetic-cob-gazebo-objects: 0.7.1-2 -> 0.7.3-1
- ros-kinetic-cob-gazebo-worlds: 0.7.1-2 -> 0.7.3-1
- ros-kinetic-cob-generic-can: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-hardware-config: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-helper-tools: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-interactive-teleop: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-light: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-linear-nav: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-map-accessibility-analysis: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-mapping-slam: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-mimic: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-model-identifier: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-monitoring: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-moveit-config: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-msgs: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-navigation: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-navigation-config: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-navigation-global: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-navigation-local: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-navigation-slam: 0.6.8-1 -> 0.6.9-1
- ros-kinetic-cob-obstacle-distance: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-omni-drive-controller: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-phidget-em-state: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-phidget-power-state: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-phidgets: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-relayboard: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-robots: 0.7.1-1 -> 0.7.2-1
- ros-kinetic-cob-scan-unifier: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-script-server: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-sick-lms1xx: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-sick-s300: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-simulation: 0.7.1-2 -> 0.7.3-1
- ros-kinetic-cob-sound: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-srvs: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-supported-robots: 0.6.12-1 -> 0.6.13-1
- ros-kinetic-cob-teleop: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-cob-trajectory-controller: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-tricycle-controller: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-twist-controller: 0.7.8-1 -> 0.7.9-1
- ros-kinetic-cob-undercarriage-ctrl: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-utilities: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-cob-voltage-control: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-costmap-converter: 0.0.9-0 -> 0.0.11-1
- ros-kinetic-dataflow-lite: 1.1.0-2 -> 1.1.2-1
- ros-kinetic-dataspeed-ulc: 0.0.4-1 -> 0.0.5-1
- ros-kinetic-dataspeed-ulc-can: 0.0.4-1 -> 0.0.5-1
- ros-kinetic-dataspeed-ulc-msgs: 0.0.4-1 -> 0.0.5-1
- ros-kinetic-eigenpy: 1.5.1-1 -> 1.6.7-1
- ros-kinetic-file-management: 1.1.0-2 -> 1.1.2-1
- ros-kinetic-generic-throttle: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-h264-encoder-core: 2.0.1-1 -> 2.0.3-1
- ros-kinetic-laser-scan-densifier: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-libdlib: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-libmavconn: 0.33.0-1 -> 0.33.3-1
- ros-kinetic-libntcan: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-libpcan: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-libphidgets: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-marti-data-structures: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-mavlink: 2019.10.10-1 -> 2019.11.11-1
- ros-kinetic-mavros: 0.33.0-1 -> 0.33.3-1
- ros-kinetic-mavros-extras: 0.33.0-1 -> 0.33.3-1
- ros-kinetic-mavros-msgs: 0.33.0-1 -> 0.33.3-1
- ros-kinetic-opengm: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-oxford-gps-eth: 1.0.0-0 -> 1.1.1-1
- ros-kinetic-plotjuggler: 2.3.6-2 -> 2.4.1-1
- ros-kinetic-raw-description: 0.7.0-1 -> 0.7.1-1
- ros-kinetic-ros-canopen: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-ros-type-introspection: 2.0.2-1 -> 2.0.4-1
- ros-kinetic-rosbag-editor: 0.3.0-1 -> 0.4.1-1
- ros-kinetic-rqt-reconfigure: 0.5.0-1 -> 0.5.1-1
- ros-kinetic-seed-r7-bringup: 0.2.0-2 -> 0.3.0-1
- ros-kinetic-seed-r7-description: 0.2.0-2 -> 0.3.0-1
- ros-kinetic-seed-r7-navigation: 0.2.0-2 -> 0.3.0-1
- ros-kinetic-seed-r7-robot-interface: 0.2.0-2 -> 0.3.0-1
- ros-kinetic-seed-r7-typef-moveit-config: 0.2.0-2 -> 0.3.0-1
- ros-kinetic-service-tools: 0.6.14-1 -> 0.6.15-1
- ros-kinetic-socketcan-bridge: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-socketcan-interface: 0.7.11-1 -> 0.7.12-1
- ros-kinetic-swri-console-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-dbw-interface: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-geometry-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-image-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-math-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-nodelet: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-opencv-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-prefix-tools: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-profiler: 0.1.0-0 -> 0.2.2-2
- ros-kinetic-swri-profiler-msgs: 0.1.0-0 -> 0.2.2-2
- ros-kinetic-swri-profiler-tools: 0.1.0-0 -> 0.2.2-2
- ros-kinetic-swri-roscpp: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-rospy: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-route-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-serial-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-string-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-system-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-transform-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-swri-yaml-util: 2.10.0-1 -> 2.11.0-1
- ros-kinetic-teb-local-planner: 0.6.13-1 -> 0.6.14-1
- ros-kinetic-tello-driver: 0.3.1-1 -> 0.3.1-2
- ros-kinetic-test-mavros: 0.33.0-1 -> 0.33.3-1
- ros-kinetic-ubiquity-motor: 0.9.0-0 -> 0.10.0-1
- ros-kinetic-um7: 0.0.5-1 -> 0.0.6-1
Removed Packages [1]:
- AWS RoboMaker
- Alexander Bubeck
- Benjamin Maidel
- Christoph Rösmann
- Daniel Miller
- Davide Faconti
- Felipe Garcia Lopez
- Felix Messmer
- Felix Zeltner
- Florian Weisshardt
- HXR
- Jannik Abbenseth
- Jordy van Appeven
- Joshua Hampp
- Justin Carpentier
- Kevin Hallenbeck
- Kris Kozak
- Ludovic Delval
- Marc Alban
- Mathias Lüdtke
- Matthias Gruhler
- Micho Radovnikovich
- Nick Rotella
- P. J. Reed
- Richard Bormann
- Rohan Agrawal
- Scott K Logan
- Vladimir Ermakov
- Yasuto Shiigi
- dfaconti
- hi.kondo
- turtlebot
