New packages for ROS 2 Dashing DIademata 2021-01-14
New year, new Dashing sync! Thanks as ever to those who continue to support the Dashing release.
It’s still several months away but the end of Dashing’s support cycle is coming in May 2021.
At the end of Dashing’s support cycle there will no longer be any active ROS 2 distribution with Tier 1 support for Ubuntu 18.04. ROS 2 Foxy Fitzroy is the latest LTS release of ROS 2 and will be supported until May 2023.
Package Updates for dashing
Added Packages [2]:
  • ros-dashing-tvm-vendor: 0.7.2-1
Updated Packages [27]:
  • ros-dashing-autoware-auto-msgs: 0.1.0-1 -> 1.0.0-1
  • ros-dashing-gurumdds-cmake-module: 0.7.7-1 -> 0.7.8-1
  • ros-dashing-rmw-gurumdds-cpp: 0.7.8-1 -> 0.7.9-1
  • ros-dashing-rmw-gurumdds-shared-cpp: 0.7.8-1 -> 0.7.9-1
  • ros-dashing-ros1-bridge: 0.7.7-1 -> 0.7.8-1
  • ros-dashing-rqt-robot-monitor: 1.0.3-1 -> 1.0.4-1
  • ros-dashing-serial-driver: 0.0.5-1 -> 0.0.6-4
  • ros-dashing-system-modes: 0.4.1-1 -> 0.4.2-1
  • ros-dashing-system-modes-examples: 0.4.1-1 -> 0.4.2-1
  • ros-dashing-turtlebot3: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-bringup: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-cartographer: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-description: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-example: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-navigation2: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-node: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-turtlebot3-teleop: 2.1.0-1 -> 2.1.1-2
  • ros-dashing-udp-driver: 0.0.5-1 -> 0.0.6-4
  • ros-dashing-v4l2-camera: 0.1.1-1 -> 0.1.2-1
Removed Packages [0]:
  • Aaron Blasdel
  • Apex.AI, Inc.
  • Arne Nordmann
  • Dirk Thomas
  • Josh Whitley
  • Joshua Whitley
  • Junho Lee
  • Sander G. van Dijk
  • Will Son
