Some confusion on my part led to an unscheduled Rolling sync happening this morning. Fortunately, there were no regressions.
If this has caused any problems, please open a detailed issue report on the issue tracker for the affected package or packages and reply to this post with links to the opened issues.
Package Updates for rolling
Added Packages [19]:
- ros-rolling-asio-cmake-module: 1.0.1-1
- ros-rolling-io-context: 1.0.1-1
- ros-rolling-mavros-extras: 2.0.4-1
- ros-rolling-micro-ros-diagnostic-bridge: 0.2.0-2
- ros-rolling-micro-ros-diagnostic-msgs: 0.2.0-2
- ros-rolling-plotjuggler-msgs: 0.2.3-1
- ros-rolling-plotjuggler-ros: 1.5.1-1
- ros-rolling-webots-ros2: 1.1.2-2
- ros-rolling-webots-ros2-control: 1.1.2-2
- ros-rolling-webots-ros2-turtlebot: 1.1.2-2
Updated Packages [75]:
- ros-rolling-controller-interface: 1.1.0-1 → 1.2.0-1
- ros-rolling-controller-manager: 1.1.0-1 → 1.2.0-1
- ros-rolling-controller-manager-msgs: 1.1.0-1 → 1.2.0-1
- ros-rolling-hardware-interface: 1.1.0-1 → 1.2.0-1
- ros-rolling-libmavconn: 2.0.3-1 → 2.0.4-1
- ros-rolling-mavros: 2.0.3-1 → 2.0.4-1
- ros-rolling-mavros-msgs: 2.0.3-1 → 2.0.4-1
- ros-rolling-realtime-tools: 2.1.1-1 → 2.2.0-1
- ros-rolling-ros1-bridge: 0.10.1-1 → 0.10.2-1
- ros-rolling-ros2-control: 1.1.0-1 → 1.2.0-1
- ros-rolling-ros2-control-test-assets: 1.1.0-1 → 1.2.0-1
- ros-rolling-ros2bag: 0.10.1-1 → 0.11.0-1
- ros-rolling-ros2controlcli: 1.1.0-1 → 1.2.0-1
- ros-rolling-rosbag2: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-compression: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-compression-zstd: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-cpp: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-interfaces: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-performance-benchmarking: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-py: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-storage: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-storage-default-plugins: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-test-common: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-tests: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosbag2-transport: 0.10.1-1 → 0.11.0-1
- ros-rolling-rosidl-adapter: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-cli: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-cmake: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-generator-c: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-generator-cpp: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-parser: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-runtime-c: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-runtime-cpp: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-typesupport-interface: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-typesupport-introspection-c: 2.5.0-1 → 3.0.0-1
- ros-rolling-rosidl-typesupport-introspection-cpp: 2.5.0-1 → 3.0.0-1
- ros-rolling-rtabmap: 0.20.13-1 → 0.20.15-1
- ros-rolling-serial-driver: 0.0.6-1 → 1.0.1-1
- ros-rolling-shared-queues-vendor: 0.10.1-1 → 0.11.0-1
- ros-rolling-sqlite3-vendor: 0.10.1-1 → 0.11.0-1
- ros-rolling-transmission-interface: 1.1.0-1 → 1.2.0-1
- ros-rolling-udp-driver: 0.0.6-1 → 1.0.1-1
- ros-rolling-webots-ros2-core: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-driver: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-epuck: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-importer: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-mavic: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-msgs: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-tesla: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-tests: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-tiago: 1.1.1-1 → 1.1.2-2
- ros-rolling-webots-ros2-universal-robot: 1.1.1-1 → 1.1.2-2
- ros-rolling-zstd-vendor: 0.10.1-1 → 0.11.0-1
Removed Packages [4]:
- ros-rolling-webots-ros2-abb
- ros-rolling-webots-ros2-demos
- ros-rolling-webots-ros2-examples
- ros-rolling-webots-ros2-tutorials
- Arne Nordmann
- Bence Magyar
- Cyberbotics
- Davide Faconti
- Dirk Thomas
- Esteve Fernandez
- Geoffrey Biggs
- Joshua Whitley
- Karsten Knese
- Mathieu Labbe
- Michel Hidalgo
- Victor Lopez
- Vladimir Ermakov
- daf
- karsten
