Hey, how can I upgrade ros-noetic to ros-noetic-desktop_full v20201214.0.0.2104301300 is the latest version available based on your source(s).
Thanks for using ROS Noetic on Windows. The latest instructions are here:
http://wiki.ros.org/Installation/Windows
With upgrade instructions at 7.
Since you want to go from Ros-Noetic to Ros-Noetic-full-desktop, you can do an in place upgrade per section 7.
Dan
Thanks
Dan
Teleop_twist_keyop.py not running in windows ros
Can you suggest any other node to use for mapping the world
