This is a great concept, but the increased complexity of managing heterogeneous systems causes significantly increased labor/time to support it which can potentially offset any cost savings for the compute. And depending on the mechanism of delivery there’s significant trust and security complexities too. Not to mention bandwidth costs, latency concerns, uptime monitoring too.
We’re working really hard to get away from this process. You’ll note that there’s been no new packages added there recently that aren’t directly developed by the core team, and those are mostly updates of existing packages.
If someone sets up a PPA for a package, they then need to also setup a build for every other potentially supported platform and arch combination. REP 2000 -- ROS 2 Releases and Target Platforms (ROS.org) I don’t think that we want to limit Nav2 to only run on specific Ubuntu arches in a PPA. And there’s also significant issues with reproducibiliity and trust for these packages too. What happens in the case of a security vulnerability. We would need to be able to respond and have pathways to patch and rebuild. We’ve had issues in the past when PPA maintainers were unavailable and we had to look at creating our own copies of it to reproduce with a fixed version. And suddenly it looks like we’re effectively recreating what we’re already doing on the ROS Buildfarm, but with more effort for a subset of platforms.
I know this would be another exception to maintain, but what about creating a (manually composed?) list of packages that would build on a larger worker? In such case, it would be sufficient to pay only for one large worker.
I believe I pointed out in the PR that this needs to be tested and not simply compiled. Openvdb’s binaries always compiled but didn’t work in practice with the compiler flags that whomever does the releases seems to use for the last couple of OS’.
Another option that just struck me is Davide’s bonxai. While not available in binaries or supported releases, if it works ‘well enough’, we can pull the headers into STVL directly and ditch Openvdb (which has been the bane of my existence since 2018 with release issue after logistical issue). I’d be willing to take a slight performance hit in exchange for easier release and deployment processes so it can be distributed wider and easier - and I think it might be a little bit faster since it doesn’t contain all the openvdb additional complexity.
Bonxai is currently under development and I am building this mostly for fun and for educational purposes. Don’t expect any API stability for the time being.
I know, but its also not going to be released into binaries. In his ROSCon talk, he mentioned just copy + pasting headers into your project, so we don’t really need API stability as long as it works
So the solution of @Rayman works . Saves a lot of buildfarm CPU cycles.
However for arm, there is no openvdb binary package, thus the buildfarm falls back to compiling openvdb from source. Leading to memory issues again.
Personally I don’t mind that arm64 fails, but maybe someone has some good suggestions? Otherwise my mailbox will keep being flooded. . And the buildfarm will probably keep trying…
