Fujitsu Laboratories of America is looking for Post-Doc
researchers or research intern’s to work in the Learning-from-Demonstration
area utilizing deep learning and machine learning.
The ideal candidate will have strong technical skills,
a passion for robotics and the drive to produce research quality work
that can lead to publications. The
successful candidate should have broad knowledge and expertise in at least one
of the following areas:
- Learning-from-Demonstration
- Deep Learning
- Machine Learning
- ROS MoveIt!
- ROS Navigation Stack
- Robot Web Tools
Qualifications
- Currently pursuing (or possesses) a M.S. or PhD in CS, or related fields
- Coursework and experience in at least one of the above-mentioned research areas.
- Proven experience developing software using C++ (Python is a plus) and ROS
- Demonstrated ability to work independently as well as within a highly-motivated team environment.
- Excellent communication skills
Edit: Aug 9, 2016 - This position has been filled.
