We’re close to having another set of packages available for indigo.
Reviewing the detected regressions I found 2 root causes.
- jsk_apc2015_common is continuing to fail to build sourcedebs, and in recent releases it has been added as a dependency. @k-okada
- There is a moved header in grid_map_ros breaking cost_map_ros I’ve filed tickets upstream https://github.com/ethz-asl/grid_map/issues/111 and downstream: https://github.com/stonier/cost_map/issues/44 @stonier @pfankhauser
Since we have over 200 packages to sync I don’t want to wait too long we may need to sync with these regressions. Without response I may attempt to roll back the grid_map changes too.
If there’s anything else I should be aware of please reply here.
