Melodic Maintainers,
Currently Melodic has no regressions and 64 packages ready to sync. I plan to hold new releases for Melodic starting Wednesday, November 14, with a sync about a week later. Please reply here if there are any outstanding issues I should know about before performing the sync.
Chris there’s a patch release for a regression in the python binding for tf2_ros that would be great to get into this sync:
Thanks for the heads up. I’ll merge that in so it can build this weekend, then I’ll probably delay the sync to main for a few days to let it soak a bit more.
When do you plan to do the actual sync?
The changes got large enough that I decided to let it sit for another few days. Assuming everything is fine with the build farm, I plan on doing the sync on Tuesday, Nov 27 now.
The sync is out
