Hi.
We have been working on an implementation of RMW using eProsima’s Micro XRCE-DDS.
We made this as part of OFERA project approach to embedded ROS 2.
In a nutshell, this approach consists on changing middleware implementation (from DDS to DDS-XRCE) and change the user API (using rclc) for cross-compile all the stack for the microcontroller. Currently, some tests have been done using NuttX over STM32.
Apart from that NuttX tests, this packages work on a Linux machine without issues and using either RCLCPP or RCLC, see the provided demos to further information.
The implementation consists of a set of new packages:
And modifications to the rclc.
All these packages work with the existing ROS 2 stack (rcl, rmw, typesupport…).
From these packages, rmw and typesupport have tests implemented.
All should compile using standard colcon tools in a ROS 2 environment, colcon build, colcon test.
You just need to add these repositories to your ROS 2 workspace.
For testing purposes, I have attached a file with all the required ROS 2 repositories and micro-ROS specific ones.
Once you cloned the repositories, these are the commands you may want to run to try it:
#Build All
colcon build --cmake-args -DBUILD_SHARED_LIBS=ON
#configure environment variables
. ~/ros2_ws/install/./local_setup.bash
#Run agent node
~/ros2_ws/install/uros_agent/lib/uros_agent/uros_agent udp 8888
#Run rclcpp demo publisher
~/ros2_ws/install/complex_msg_publisher_cpp/lib/complex_msg_publisher_cpp/complex_msg_publisher_cpp
#Run rclc demo publisher
~/ros2_ws/install/complex_msg_publisher_c/lib/complex_msg_publisher_c/complex_msg_publisher_c
#Run rclcpp demo subscriber
~/ros2_ws/install/complex_msg_subscriber_cpp/lib/complex_msg_subscriber_cpp/complex_msg_subscriber_cpp
#Run rclc demo subscriber
~/ros2_ws/install/complex_msg_subscriber_c/lib/complex_msg_subscriber_c/complex_msg_subscriber_c
Furthermore, you can run Micro ROS packages tests with:
colcon test --packages-select rosidl_typesupport_microxrcedds_c rosidl_typesupport_microxrcedds_c_tests rosidl_typesupport_microxrcedds_cpp rosidl_typesupport_microxrcedds_cpp_tests rosidl_typesupport_microxrcedds_test_msg rmw_microxrcedds
All these packages are work in progress and will be updated and extend API. Currently, only publish/subscribe API has been implemented.
Currently working on polishing a NuttX build system.
