The ROS PMC meeting for this week was on Tuesday. The notes from the meeting are available at ROS PMC weekly meeting agenda
This week we discussed:
- Rosdep review questions
- What to do in the case that an “alternative platform” key appears as automated feedback in rosdistro? add 'python3-wheel' by christianrauch · Pull Request #44501 · ros/rosdistro · GitHub
- Conclusion: When possible, please ask contributors to add rules for other operating systems. We aren’t directly supporting these (like opensuse), but if there is a rule that matches, then it’s low cost to get it in at the time of the original rosdep PR
- Does adding a package break API/ABI and justify a major version bump? (rmw: 7.7.0-1 in 'rolling/distribution.yaml' [bloom] by ahcorde · Pull Request #44482 · ros/rosdistro · GitHub)
- Conclusion: In this case, we are okay, as adding the package doesn’t incur changes. In downstream packages (rmw implementations), we likely want to bump majors to reflect the new dependency.
- Kilted Development Updates
- Progress on
rmw_zenoh
- Progress on
fastdds
name change and 3.2 bump - Progress on Conda
- We are awaiting a meeting with infra and all ROS bosses before merging as it will have packaging impacts to all released distributions.
- Progress on
- Agenda
- Recursive node parameter update (Cannot create subscription/publisher with QoS override parameter via parameter callback. · Issue #2741 · ros2/rclcpp · GitHub)
- Managed transform listener concept: (Introduce managed transform buffer to geometry2 · Issue #758 · ros2/geometry2 · GitHub)
- Collisions between launch arguments: (argument collision in included files (xml and yaml) · Issue #815 · ros2/launch · GitHub)
- Changing
geometry_msgs/PoseStampedArray
tonav_msgs/Goals
(Move geometry_msgs/PoseStampedArray to nav_msgs/Goals by tfoote · Pull Request #269 · ros2/common_interfaces · GitHub)
The next ROS PMC meeting will be on February 25, 2025: Open Source Robotics Foundation official events.
The ROS PMC meets on a weekly basis to discuss details of the ROS 2 core. This is a working meeting, where only members of the ROS PMC and associated committers may speak. However, anyone is welcome to join as an observer. Come and find out how ROS 2 is developed!
If you have questions or comments, please leave them in this thread.
