ROS2 Real-time Working Group Online Meeting 2 - Aug 21st, 2019 between 7AM and 8AM PDT (UTC-7)
Hi all,
this is a call for our 2nd ROS2 Real-time Working Group meeting: Aug 21st, 2019 between 7AM and 8AM PDT (UTC-7).
I would like to propose the following agenda constructed from the action items of the previous meeting: ROS2 Real-time Working Group Online Meeting - May 20th, 2019 between 7AM and 8AM PDT (UTC-7) - #8 by Dejan_Pangercic
  1. [10min] Create an rmw implementation which works for a single process. Once that works connect with the underlying data link (e.g. TSN). Measure: malloc/realloc calls, page faults, context switches, memory consumption, blocking calls, … RTI Connext Micro is a suitable DDS implementation for something like this due it its staticity and intra-process communication feature.
    1. AI : find someone that will lead this work.
    2. I propose to ask one of the following folks to lead this
      1. GitHub - ros2/rmw_fastrtps: Implementation of the ROS Middleware (rmw) Interface using eProsima's Fast RTPS. (Jaime, Miguel) or
      2. GitHub - ros2/rmw_cyclonedds: ROS 2 RMW layer for Eclipse Cyclone DDS (Eric, Joe)
      3. @lbegani also volanteered
  2. [10min] Performance testing on target hardware
    This is the topic that I am adding in addition and it was originally proposed by Acutronic Robotics. The proposal is to create a buildfarm with couple of select computers (ECUs) on which to run the GitHub - ApexAI/performance_test: **This project is deprecated** Go to https://gitlab.com/ApexAI/performance_test and measure performance regressions. @Dejan_Pangercic realized that several parties are trying to work on this (Amazon, iRobot, Apex, eProsima, Open Robotics, …)
    We would need to figure out the following:
    1. target HW => could Amazon host?
    2. target (RT)OS => Linux with RT-PREEMPT, QNX, VxWorks, …
    3. how to automate flashing of (RT)OS and provisioning of DDS, ROS 2 and GitHub - ApexAI/performance_test: **This project is deprecated** Go to https://gitlab.com/ApexAI/performance_test => Apex works on this
    4. how to configure and automate running of GitHub - ApexAI/performance_test: **This project is deprecated** Go to https://gitlab.com/ApexAI/performance_test in a clean environment => Apex works on this
      1. how to run Alpha release of ROS 2 tracing tools
    5. how to store the results => Apex works on this
    6. how to visualize the results (e.g. What is Munin ? — Munin 2.999.16-detached-2023-06-14-c98-ga24eda76 documentation) such that we can compare historical runs, view results for different configurations of HW, RTOS, DDS, ROS 2 => ???
    7. which additional metrics do we want => ???
  3. [10min] Invest in the tools for static and dynamic code analysis and tracing and carefully scan the code.
    1. AI: create a shared repository for above tools. Bosch will e.g. open-source their integration of LTTng in ROS2. Silexica is integrating they dynamic analyser.
    2. Bosch already made the first steps: ROS2 Real-time Working Group Online Meeting - May 20th, 2019 between 7AM and 8AM PDT (UTC-7) - #11 by christophebedard
    3. Silexica dynamically analysed Autoware.Auto: Merge requests · AutowareAuto / AutowareAuto · GitLab
    4. @Ingo_Lutkebohle can you take a lead on this?
  4. [20min]
    1. AI : present the paper in detail in one of the next meetings.
    2. @tobiasblasscan you do this in 1/2h?
  5. [10min]
    • perform memory audit in rmw, rcl and rclcpp (remove unneeded memory allocations)
    • split memory allocation in init and runtime phases, avoid memory fragmentation
    • remove all blocking calls (or replace with timed calls, e.g. mutex vs timed_mutex )
    Document current state of the art. Someone remarks that there were still mutexes used in e.g. rmw or rclcpp. Memory is still being allocated/de-allocated when receiving messages.
    1. AI2 : get William to present his findings
    2. @Dejan_Pangercic will get William to present this
LMK if you agree with the agenda and if you can join.
D.
@vmayoral @tobiasblass @Ingo_Lutkebohle @davecrawley @aohsato @gbiggs @lbegani @carlossv @nburek See above.
@wjwwood @Jaime_Martin_Losa @mkhansen @anup.pemmaiah @joespeed see above.
One remark - regarding the following action item:
  • Propose a use case => requirements => architecture => hardware
  • Proposed canonical use case: a vehicle/robot encounters an obstacle and has to stop safely for it
  • Proposed other use case: autonomous driving
  1. AI : Dejan to provide a use case description and requirements
  2. I did not have time to provide this. @gbiggs and one of our engineers are working on this however.
Looks good. Can you also please share the meeting link.
@eboasson @joespeed will join, possibly @niels.kortstee too
@ishugoel and I are also interested in joining this meeting. We have been looking at the current implementation of the SingleThreadedExecutor to investigate the high CPU overhead. We have an ongoing discussion here: SingleThreadedExecutor creates a high CPU overhead in ROS 2 . As a first step we are starting work on creating a static version of the executor to investigate how much performance can be gained (POC). We think this is a separate issue from the scheduling “problem” discussed in Tobias’ work. Both issues are important to us and probably to others who want to run a “normal” ROS2 stack on an embedded board.
@Dejan_Pangercic I’d like to join the WG as a listener for the time being
Yes, that should be enough.
Very nice work on the CPU overheads!. I agree that the two problems are not related.
@Dejan_Pangercic
I’d like to join, thanks for taking care of this thread.
tomoya
Hi @Dejan_Pangercic,
Is it the same Zoom meeting like last time?
I’d like to join it.
Kind Regards,
Andrei
We might want to spend some more time thinking about this, before someone goes off and starts on it. I’m not sure 10 minutes is enough here – maybe have it as the main topic of an upcoming meeting?
I think there might be a connection to tracing here… Just saying :wink:
In principle yes, but I’m not available on the 21st of August, as I’m on vacation. Let’s connect afterwards.
Hi all,
the meeting details are here:
Topic: My Meeting
Time: Aug 21, 2019 07:00 AM Pacific Time (US and Canada)
Join Zoom Meeting
One tap mobile
+16699006833,264081213# US (San Jose)
+19294362866,264081213# US (New York)
Dial by your location
+1 669 900 6833 US (San Jose)
+1 929 436 2866 US (New York)
Meeting ID: 264 081 213
Find your local number: https://zoom.us/u/aAmxdSnyw
Yes - we absolutely should not do this without the proper design document.
Correct. Added.
OK.
Wednesday, August 21, 2019 2:00 PM
This is the same time as an AWF board meeting so I may or may not be able to join. Don’t wait for me if I’m not there.
I would like to join.
Sincerely,
Kosuke
Sorry guys I was stuck on a plane while this meeting was happening and I only just got clear. Are there any meeting minutes for this?
David
@Dejan_Pangercic Can you please share MoM or meeting recording
@lbegani and all:
here the recordings of the 2nd meeting (I will follow-up with the short transcription tomorrow):
Topic: 2nd ROS Real-time working group meeting
Start Time : Aug 21, 2019 06:51 AM
Meeting Recording:
https://zoom.us/recording/share/DY2qaOx4qqzUyJaIxsgdLEhfIdLdl4nPc0forr7e2S-wIumekTziMw
Hello,
@Dejan_Pangercic
I would like to join this group and attend the next meeting please.
Thank you,
