Dear ROS community,
I’ve got a quick update regarding ROSbot 2.0 platform:
- We’ve introduced a new ROS-based web user interface for ROSbot. You can set it up in 5 mins in your local network or via the internet. Use ROSbot in both remote control and autonomous mode, and test its functionalities, without any coding. It’s open source an already on our GitHub page. Web UI works with any ROSbot 2.0 version and is available here: https://husarion.com/tutorials/howtostart/rosbot---quick-start/
We’ve updated Sharp distance sensors to VL53L0X time-of-flight distance sensor, which offers bigger range, higher accuracy and higher immunity to interferences
We’ve increased battery capacity from 2600 mAh to 3500 mAh
We’ve improved the charging process by providing stronger and more reliable chargers
We are now adding USB Ethernet Adapter to each ROSbot 2.0. set for quick network setup
The complete set looks like this:
Full specs are available here: https://husarion.com/manuals/rosbot-manual/ .
Cheers!
