[TB3] TurtleBot3 with Laser Distance Sensor (LDS)
#1
Hi everyone :slight_smile:
TurtleBot3 release come just next month.
Are you curious about the LDS on the TurtleBot3?
LDS can be rotated 360 degrees.
It is a key part in create slam and navigation. even create 3D map!!!
And less than half the price of a lidar sold on the market. But the functions are almost the same.
You can see it soon. :smiley:
Thank you :slight_smile:
This is the cheapest 360 degrees LiDAR in the world I know. :smile:
For more information; Please see the detailed spec on TurtleBot3 wiki.
http://turtlebot3.robotis.com/en/latest/appendix_lds.html
The design reminds me of the RP-LIDAR (http://www.robopeak.com/blog/?p=278).
Can you comment on expected uptime? E.g., if I begin to operate the sensor and do not stop, how long before the device may need to be rebooted?
I am motivated to ask because I noticed recently that after approximately 3 days of continuous operation of an RP-LIDAR that I have, the motor stopped and would not return to operation until after I cycled power. I plan to conduct a more thorough study of product lifetime and durability of the RP-LIDAR.
#4
@Pyo, do you have any information on the cost?
I think it is hard to expect long operation life in low-cost LiDAR.
I will ask the engineer about the expected time for the operation time. :slight_smile:
#6
After the launch of TurtleBot 3, the products for each accessory are going to start selling in June.
The price is still undecided, but we think it is under $150. :slight_smile:
@Pyo did you get any data about expected lifetime under continuous operation?
The following attachments include the contents like basic performance, measurement performance, mechanism layout, optical path, data information, pin description, command. But, I can’t find information about the lifetime from the manufacturer.
#9
Ask you engineers what is the mean time between failures (MTBF) data they should have and hopefully share.
