Piggy-backing on the announcement of rospy2, I too am trying to make it easier to migrate ROS 1 Python code to ROS 2. In particular, I’ve made the new package tf_transformations
to fill the hole left by the useful ROS 1 library transformations.py
In short, if you wrote the following in ROS 1,
from tf.transformations import euler_from_quaternion
the only change you need to your code in ROS 2 is
from tf_transformations import euler_from_quaternion
For more information about the rationale behind the library, why it wasn’t already in ROS 2, the installation procedures and more, please see the project README. Note that the library is currently making its way through the buildfarm for foxy, galactic and rolling, so exciting things are coming soon.
