ROS 2 Tutorial on transformation
Hi there!
If you’re looking for some learning resources to gain hands-on practice with ROS 2 for mobile robotics, we have just published a new ROS 2 tutorial, focusing on the topic of transformation.
ros2_tutorial_7_cover
In the tutorial, you can learn how to:
  • Perform transformations using the tf2 package
  • Visualize them in TF_Echo, TF_Tree and rviz
  • Simulate the mutual position of moving objects thanks to broadcasting and listening to transformation information.
This tutorial is part of the complete ROS 2 tutorial series, covering topics ranging from the basics of ROS 2 to kinematics, visualization, OpenCV tracking, and connecting robots over the Internet. The tutorials provide both theoretical explanations and practical examples that you can deploy on a physical ROSbot or in simulation. If you find the tutorials helpful, be sure to stay tuned for new tutorials on SLAM and navigation coming in two weeks!
Hi!
Is it possible to broadcast the updated urdf file transformations without killing the nodes in the launch file and relaunching again?
I made one service and client to parse the urdf file. As i parse the urdf file it updates the urdf file but the transformations in rviz are not updated and i assume the urdf file is somewhere in the cache which cannot be updated without killing the nodes from the launch file.
Is there any solution to fix such scenario?
