Upgrade RCM to version V2.0.0, this is a big upgrade
What problem does RCM solve? RCM was initially designed to manage installation scripts of various ROS1/ROS2 source codes and startup scripts through the interface. After continuous expansion and improvement, it has now become a bash-based shell script management tool under Ubuntu/Linux.
RCM is a bash-based shell script management tool. After installation, the shell script that meets the definition can be converted into a system command with RCM as the command, script path, and script name as the subcommand. At the same time, it provides a powerful Tab auto-completion function to realize quick search of scripts.
Three modes are provided for running scripts:
Auto-completion mode: rcm (supported by 2.x series and above)
Search mode: rcm -s (supported above 1.x)
Interface mode: rcm-gui or click the RCM (commands) icon (supported by 1.x series or above)
new features
  • Change the running mode and change the search mode to automatic completion mode, similar to the ros2 one-line command style
  • Unified the style, the main command is rcm, the desktop moderator command is rcm-gui
  • Unified script style, making scripts more independent and easier to expand
  • Add more ros2 related scripts
  • Added convenient mechanisms for creating directories and scripts
  • Add ailibot robot simulation development kit
  • Add ailibot2 robot simulation development kit
  • Add ailibot model development package
demo
  • Query script, use tab method to automatically complete subcommands
rcm <tab><tab> <tab><tab>
rcm-completion
  • install ros2
rcm ros2 install_ros2_now
  • install ros1
rcm ros1 install_ros1_noetic
  • Update rosdep for mainland China
rcm common update_rosdep_tsinghua
  • install turtlebot3
rcm ros1_tb3 install_tb3_noetic_apt
  • install turtlebot4
rcm ros2_tb4 install_tb4_galactic_apt
  • Create a directory
rcm system create --dir poker --dirdesc "poker script dirctory"
rcm-create-dir
  • Create script
rcm system create --dir poker --script build --scriptdesc "to build rcm"
rcm-create-script
Easy to Installation:
curl -k https://www.ncnynl.com/rcm.sh | bash -
About the code :
gitee repo
github repo
