My lab is looking for a cheap rotating 3D LiDAR that has a ROS package, so that we can experiment point cloud registration techniques on it.
However, I have trouble finding a cheap LiDAR that also happens to have a ROS package…
I was thinking about Velodyne, because I saw that someone built a package porting the velodyne driver to ROS, but I want an idea of what 3D rotating LiDAR people generally use.
RPLidar is the cheapest LIDAR solution I’ve seen, but I’m only aware of them producing planar-scan outputs… Perhaps turning the output of a depth camera (e.g., the RealSense) being turned into a point cloud is close enough to the desired 3d output?
Alternatively, the RPLidar could be made 3d by putting it on a tilt mechanism… wouldn’t be too tricky, but I would only go that route if the highest priority is to cut cost.
How would you define cheap? Hundreds of dollars? Thousands of dollars?
The cheapest 3D LIDAR we’ve used is a Velodyne VLP-16 which is an older model at this time, but proven in use. Ouster and Hesai offer LIDAR’s which are 32 beams, and with different features with similar pricing.
All three of these offer ROS packages, and in general provide very similar LIDAR point output over Ethernet, so in our experience it’s not been complex to adapt ROS packages.
Each LIDAR is subject to common and unique systematic issues, and one may be more suitable depending on your operating environment and use case.
All are in the several thousands of US dollars range new.
My personal recommendation would be Ouster, I’m a big fan of their sensors, but yes you’re talking in the thousands. By comparison to something like a Velodyne, Ouster is much cheaper, but they’re still professional tools with professional price tags. I want to say the 16 beam Ouster is something like 3-4k.
A little bit of context: my lab is researching point cloud registration techniques and we wanted to apply our findings to a 3D LiDAR without spending more than ~3-4 thousands.
I will take a look at Ouster, Hesai and Velodyne and make a decision. Thank you very much for your help !
Do you require a spinning Lidar? I prefer the ‘solid state’ type myself. I put solid state in quotes because most of them have moving parts, just not a spinning tower. For a while they were quite a challenge to use because of the very different scan patterns, but I believe most of the ROS drivers now output a more traditional ‘Velodyne’ compatible pattern. Livox has the best prices I have seen this far, and as a bonus they were shipping as of two days ago. I’ve had a Mid40 for some time now and just acquired an Avia.
I have also tried the livox mid 360 and been impressed with the performance and cost. It also has a built in imu, which is nice to have depending on your use case. One thing about it that caught me off guard though is the fact that it does not come with a connector for data and power transmission. You have to buy an aviation connector from livox or fabricate your own connector for it (maybe that is common in 3D lidar?). But even then, the total cost is still cheaper than others.
The unitree L1 lidar is the least expensive 3D lidar you will find, but idk anyone who has tried it.
Beware, it doesn’t work with iron out of the box as no PR’s are accepted by Livox.
Of course hardware performance is the most important criteria here, but sometimes I’m stunned with the lack of responses from sensor suppliers to their repositories. Or to contributions from the community.
HI ,
i used livox mid 360 in ros2 humble but getting some error like bind error if anybody know please tell me:
user@user:~/ws_livox/src$ ros2 launch livox_ros_driver2 rviz_MID360_launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2025-06-10-17-51-59-952149-user-19932
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [livox_ros_driver2_node-1]: process started with pid [19933]
[INFO] [rviz2-2]: process started with pid [19935]
[livox_ros_driver2_node-1] [INFO] [1749558120.043799958] [livox_lidar_publisher]: Livox Ros Driver2 Version: 1.2.4
[livox_ros_driver2_node-1] [INFO] [1749558120.044274461] [livox_lidar_publisher]: Data Source is raw lidar.
[livox_ros_driver2_node-1] [INFO] [1749558120.044300504] [livox_lidar_publisher]: Config file : /home/user/ws_livox/install/livox_ros_driver2/share/livox_ros_driver2/launch_ROS2/../config/MID360_config.json
[livox_ros_driver2_node-1] LdsLidar *GetInstance
[livox_ros_driver2_node-1] config lidar type: 8
[livox_ros_driver2_node-1] successfully parse base config, counts: 1
[livox_ros_driver2_node-1] bind failed
[livox_ros_driver2_node-1] Failed to init livox lidar sdk.
[livox_ros_driver2_node-1] [ERROR] [1749558120.047151608] [livox_lidar_publisher]: Init lds lidar fail!
