Belatedly announcing the redefinition of meta-ros Milestone 17
LG Electronics stopped maintaining meta-ros and meta-ros-webos in December 2021. Milestone 17 has been redefined to be the work done up until then, namely support for the ROS distro releases current at the middle of November 2021, for webOS OSE v2.14.0, and for OpenEmbedded release series branches as of the beginning of December 2021, including kirkstone as it was then. It also reduces the support for ROS 2 dashing and OpenEmbedded gatesgarth to “best-effort”, and drops support for OpenEmbedded zeus.
A new revision 51 of Superflore OE Recipe Generation Scheme updated for this has been published. Its log is here. A “rich diff” of the changes made since the previous revision is here.
A new revision 24 of the OpenEmbedded Build Instructions updated for this has also been published. Its change log is here. A “rich diff” of the changes made since the previous revision is here.
The PR-s to complete the milestone will be merged once verification builds have completed (thanks @robwoolley!).
The future maintenance of meta-ros was discussed in the OSRF TSC January 2022 meeting post.
