Good evening dear community of ROS, I am a Cuban boy of 12 years who by chance discovered the simulator gazebo ros, but due to the poor communication in my country I have limited access to the Internet. Currently I set my goal to develop the simulation of a quadrator in ros, which is able to locate a mobile platform, and land on it, but I have stumbled on the first problem to achieve it, I do not know how to implement a controller that allows me to rotate the quadrator on the z-axis, that is, its yaw, from its rotation matrix.
Best regards, God bless you.
PS: I attached a part of the code, in which you can see the way I currently perform the rotation without using the rotation matrix.
//-------------- YAW CONTROL ----------------
max_grad = 180.0;
yaw_error = yaw_reference - yaw;
u = kp_yaw*yaw_error/max_grad;
commandPilot.angular.z = u;
//------------ ALTITUDE CONTROL ---.---------
altura_error = alt_ref - altitude;
commandPilot.linear.z = kp_alt * altura_error;
if(commandPilot.linear.z > 0.5)
commandPilot.linear.z = 0.5;
if(fabsf(altura_error) < 0.01 && fabsf(yaw_error) < 0.5)
state = 1;
commandPilot.linear.x = 0;
commandPilot.linear.y = 0;
pose_xi = start_pose.position.x;
pose_yi = start_pose.position.y;
//~ ROS_INFO_STREAM("Gazebo pose: X = " << pose_xi << " Y = " << pose_yi);
}else
if(state == 1)
putText(front_image," Dist: "+ stDist.str() + " Dist error: "+ stErrorDist.str() + " Signal: " + stSignal.str(), Point( 5, 55), FONT_HERSHEY_COMPLEX_SMALL, 0.7, CV_RGB( 255, 255, 255), 1, 1);
dist_x = distancia - fabsf(pose_xi);
dist_error = dist_x - start_pose.position.x;
signal = kp * dist_error;
commandPilot.linear.x = signal;
if(fabsf(dist_x) < 0.01)
void image_viewer::Ardrone_odom(const sensor_msgs::Imu::ConstPtr &odom)
odom_ARdrone_x = odom->orientation.x;
odom_ARdrone_y = odom->orientation.y;
odom_ARdrone_z = odom->orientation.z;
odom_ARdrone_w = odom->orientation.w;
//my code
/*x0 = odom_ARdrone_x;
y0 = odom_ARdrone_y;
z0 = odom_ARdrone_z;
w0 = odom_ARdrone_w;*/
tf::Quaternion q1(odom_ARdrone_x,odom_ARdrone_y,odom_ARdrone_z,odom_ARdrone_w);
tf::Matrix3x3 m(q1);
//Found final position
//z1 = r31x0 + r32y0 + r33z0
m.getRPY(roll, pitch, yaw);
roll = (roll * 180) / M_PI;
pitch = (pitch * 180) / M_PI;
yaw = (yaw * 180) / M_PI;
