We are pleased to announce our Deep Neural Net object detection node dnn_detect.
For robots to be useful servants, they need to be able to recognize objects so that actions on and with those objects can be programmed. For example, in our robotic cocktail waiter application, the robot has to be able to find people in the room to serve.
Because this is important functionality, we have developed a generalized deep neural net node that can recognize twenty common household objects using monocular camera data. The results look like this:
Our node uses the [Deep Neural Network module in OpenCV] (https://docs.opencv.org/3.3.0/d2/d58/tutorial_table_of_content_dnn.html) to find a variety of objects using a pretrained model. The class of the objects detected, bounding boxes, and the confidence of the classifications are published as a ROS topic. This allows the robot to interact with its environment in meaningful ways.
Have an issue, or an idea for improvement? Open an issue or PR on the GitHub repo.
Very interesting node Dave!
I think that this is a very interesting subject for an interview at the ROS Developers podcast. Would you like to be interviewed at the podcast to explain there how it works and how to use it?
Great.
works out of the box now.
It will be good to update the wiki page doc.
I just noticed that sometimes recognition is not perfect.
I showed it a mobile phone and it says a bottle.
Yes, it reports both the object and the confidence that the object is what it says it is. It will continue reporting objects even if the confidence is quite low - frequently as low as 30%. If you want to improve specificity for your application then filter out objects that report with low confidence.
It is a much better choice to have the algorithm report objects and be honest about how likely it thinks it is that actual object, than to not report the object at all.
Very nice work, Dave.
Did you consider using vision_msgs instead of new custom messages? This would make this and other detector more interoperable, see also this discussion.
min_confidence is a parameter of the node. However, not all of the node’s parameters are exposed as arguments to the sample launch file. If you want to try different parameters, you should create your own launch file and add
