Deep Neural Network on Embedded?
#1
I recently implement couple of algorithms for Deep Learning, which provides fast inference on an embedded devices.
One of them is called ‘LCNN’, you can find the original paper here : https://arxiv.org/abs/1611.06473
And I implemented it with tensorflow,
This codes compress alexnet which takes roughly 150ms or more on a single core cpu,
to a sparse convolutional layered network which takes 10~50ms on the same environment.
https://github.com/ildoonet/tf-lcnn/raw/master/images/timeline_alexnet.png
So… based on these new technologies, i am looking for an idea to try.
Like openpose on a robot : Human Pose Estimation Deep Learning Model (OpenPose) ROS Package
Any Thoughts?
#2
@ildoonet, that’s pretty cool. What embedded platform are you working on? The results are pretty interesting. Well done.
#3
It’s for snapdragon cpus like smartphones.
Also I’m working on arm cpus.
Also, this codes is not optimized for specific cpu architecture, It can be improved further.
#4
That’s really cool!
Do you have trained neural nets to go along with it?
#5
I have alexnet which 20 times faster than the original one. I will add more models. Do you have any particular model you want?
