Is there a ROS 2 gazebo project for humanoids robots?
Dear ROS community,
I was researching if there are ROS 2 Gazebo project for humanoid robots that would facilitate in learning robot locomotion and whole-body motion planning. I am looking towards humanoids similar to Unitree’s H1/H2.
A research scientist from ETH Zurich pointed me to the Issac Gym environment that comes with the assets for H1/H2. But as far as I understand, that simulation pipeline does not use any ROS, and is meant for RL like research.
The closet project I found was Unitree’s ROS 1 project GitHub - unitreerobotics/unitree_ros but it has not been updated for the newer ROS 2 and Gazebo.
Thank you for your time.
With best,
Azmyin
I was just at the Humanoids conference and I didn’t see anything that fits your description.
I would reach out to either Unitree or Red Rabbit Robotics and see if they have a full Gazebo sim on their roadmap.
Hello @azmyin12!
You can find our TALOS/REEM-C Simulations and the related packages needed for the Gazebo simulation on our GitHub page: GitHub - pal-robotics/talos_simulation
For ROS 1 : GitHub - pal-robotics/talos_simulation at kinetic-devel
For ROS 2: https://github.com/pal-robotics/talos_simulation/tree/humble-devel
I hope this information helps you.
Thank you!
Hi @saikishor thank you very much for pointing to TALOS and REEM-C packages compatible with ROS 2. I looked at the package.xml file for TALOS, is it currently compatible only with Gazebo 6 (Ignition Fortress)?
Hello!
Sorry for the late reply. Yes it is compatible on Humble as of now. Work is underway to make it available in Jazzy soon with Ignition.
