Hi, micro-ROS community!
As you might know, PlatformIO has become a really popular solution for embedded development, it provides a complete embedded development environment compatible with tons of boards, frameworks, and platforms.
Most of you have been using our micro-ROS for Arduino library to integrate micro-ROS in the PlatformIO environment, but we think that we can do it much better. So, we have been developing a proper solution for integrating the micro-ROS build system in the PlatformIO build system. You can check it here.
micro-ROS for Arduino provide a precompiled set of libraries due to the lack of advanced features for building the micro-ROS stack in the Arduino IDE/CLI development environment. Meanwhile, PlatformIO allows complex build processes where the micro-ROS library can be compiled just in time for the used platform avoiding cross-compilation compatibility issues. Also, it provides a much more flexible way of configuring the micro-ROS library with custom packages and/or custom middleware configurations.
We have reached a semi-functional status where some platforms are supported but we need your help to provide feedback and comments about your needs as micro-ROS developers. So we are opening a beta testing period before releasing this library on the PlatformIO registry.
We ask the community to:
- test current available boards and transports
- add / request / recommend new boards and transports
- test the whole functionality and advice new features
Please feel free to comment in the micro-ROS for PlatformIO repo discussion panel
Sincerely, the micro-ROS team.
