Package Updates for Humble
Added Packages [9]:
- ros-humble-etsi-its-vam-ts-coding: 2.3.0-1
- ros-humble-etsi-its-vam-ts-coding-dbgsym: 2.3.0-1
- ros-humble-etsi-its-vam-ts-conversion: 2.3.0-1
- ros-humble-etsi-its-vam-ts-msgs: 2.3.0-1
- ros-humble-etsi-its-vam-ts-msgs-dbgsym: 2.3.0-1
- ros-humble-sbg-driver: 3.2.0-1
- ros-humble-sbg-driver-dbgsym: 3.2.0-1
- ros-humble-web-video-server: 2.0.1-1
- ros-humble-web-video-server-dbgsym: 2.0.1-1
Updated Packages [140]:
- ros-humble-clearpath-msgs: 0.3.0-2 → 1.0.0-1
- ros-humble-clearpath-platform-msgs: 0.3.0-2 → 1.0.0-1
- ros-humble-clearpath-platform-msgs-dbgsym: 0.3.0-2 → 1.0.0-1
- ros-humble-control-toolbox: 3.2.0-1 → 3.3.0-1
- ros-humble-control-toolbox-dbgsym: 3.2.0-1 → 3.3.0-1
- ros-humble-etsi-its-cam-coding: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-coding-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-msgs: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-msgs-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-ts-coding: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-ts-coding-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-ts-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-ts-msgs: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cam-ts-msgs-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-coding: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-conversion-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cpm-ts-coding: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cpm-ts-coding-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cpm-ts-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cpm-ts-msgs: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-cpm-ts-msgs-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-denm-coding: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-denm-coding-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-denm-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-denm-msgs: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-denm-msgs-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-messages: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-msgs: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-msgs-utils: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-primitives-conversion: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-rviz-plugins: 2.2.0-1 → 2.3.0-1
- ros-humble-etsi-its-rviz-plugins-dbgsym: 2.2.0-1 → 2.3.0-1
- ros-humble-generate-parameter-library: 0.3.8-3 → 0.3.9-1
- ros-humble-generate-parameter-library-example: 0.3.8-3 → 0.3.9-1
- ros-humble-generate-parameter-library-example-dbgsym: 0.3.8-3 → 0.3.9-1
- ros-humble-generate-parameter-library-py: 0.3.8-3 → 0.3.9-1
- ros-humble-generate-parameter-module-example: 0.3.8-3 → 0.3.9-1
- ros-humble-lanelet2: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-core: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-core-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-examples: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-examples-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-io: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-io-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-maps: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-matching: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-matching-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-projection: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-projection-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-python: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-python-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-routing: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-routing-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-traffic-rules: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-traffic-rules-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-validation: 1.2.1-1 → 1.2.2-1
- ros-humble-lanelet2-validation-dbgsym: 1.2.1-1 → 1.2.2-1
- ros-humble-launch-pal: 0.4.0-1 → 0.7.0-1
- ros-humble-mrpt-apps: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-apps-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libapps: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libapps-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libbase: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libbase-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libgui: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libgui-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libhwdrivers: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libhwdrivers-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libmaps: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libmaps-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libmath: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libmath-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libnav: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libnav-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libobs: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libobs-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libopengl: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libopengl-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libposes: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libposes-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libros-bridge: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libros-bridge-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libslam: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libslam-dbgsym: 2.14.3-1 → 2.14.4-1
- ros-humble-mrpt-libtclap: 2.14.3-1 → 2.14.4-1
- ros-humble-mvsim: 0.11.0-1 → 0.11.1-1
- ros-humble-mvsim-dbgsym: 0.11.0-1 → 0.11.1-1
- ros-humble-octomap-rviz-plugins: 2.1.0-1 → 2.1.1-1
- ros-humble-octomap-rviz-plugins-dbgsym: 2.1.0-1 → 2.1.1-1
- ros-humble-omni-base-2dnav: 2.3.0-1 → 2.4.0-1
- ros-humble-omni-base-bringup: 2.4.0-1 → 2.4.1-1
- ros-humble-omni-base-controller-configuration: 2.4.0-1 → 2.4.1-1
- ros-humble-omni-base-description: 2.4.0-1 → 2.4.1-1
- ros-humble-omni-base-gazebo: 2.1.0-1 → 2.2.0-1
- ros-humble-omni-base-laser-sensors: 2.3.0-1 → 2.4.0-1
- ros-humble-omni-base-navigation: 2.3.0-1 → 2.4.0-1
- ros-humble-omni-base-rgbd-sensors: 2.3.0-1 → 2.4.0-1
- ros-humble-omni-base-robot: 2.4.0-1 → 2.4.1-1
- ros-humble-omni-base-simulation: 2.1.0-1 → 2.2.0-1
- ros-humble-parameter-traits: 0.3.8-3 → 0.3.9-1
- ros-humble-pmb2-bringup: 5.3.0-1 → 5.3.1-1
- ros-humble-pmb2-controller-configuration: 5.3.0-1 → 5.3.1-1
- ros-humble-pmb2-description: 5.3.0-1 → 5.3.1-1
- ros-humble-pmb2-robot: 5.3.0-1 → 5.3.1-1
- ros-humble-pose-cov-ops: 0.3.12-1 → 0.3.13-1
- ros-humble-pose-cov-ops-dbgsym: 0.3.12-1 → 0.3.13-1
- ros-humble-python-mrpt: 2.14.3-1 → 2.14.4-1
- ros-humble-realtime-tools: 2.6.0-1 → 2.7.0-1
- ros-humble-realtime-tools-dbgsym: 2.6.0-1 → 2.7.0-1
- ros-humble-sick-scan-xd: 3.5.0-1 → 3.6.0-1
- ros-humble-sick-scan-xd-dbgsym: 3.5.0-1 → 3.6.0-1
- ros-humble-tiago-bringup: 4.5.0-1 → 4.6.0-1
- ros-humble-tiago-controller-configuration: 4.5.0-1 → 4.6.0-1
- ros-humble-tiago-description: 4.5.0-1 → 4.6.0-1
- ros-humble-tiago-moveit-config: 3.0.18-1 → 3.1.0-1
- ros-humble-tiago-robot: 4.5.0-1 → 4.6.0-1
- ros-humble-ur: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-bringup: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-calibration: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-calibration-dbgsym: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-controllers: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-controllers-dbgsym: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-dashboard-msgs: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-dashboard-msgs-dbgsym: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-description: 2.1.7-1 → 2.1.8-2
- ros-humble-ur-moveit-config: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-robot-driver: 2.2.15-1 → 2.2.16-5
- ros-humble-ur-robot-driver-dbgsym: 2.2.15-1 → 2.2.16-5
- ros-humble-urdf-test: 2.0.3-1 → 2.1.0-1
- ros-humble-velodyne: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-driver: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-driver-dbgsym: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-laserscan: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-laserscan-dbgsym: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-msgs: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-msgs-dbgsym: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-pointcloud: 2.4.0-1 → 2.5.1-1
- ros-humble-velodyne-pointcloud-dbgsym: 2.4.0-1 → 2.5.1-1
Removed Packages [0]:
- Andrea Capodacqua
- Armin Hornung
- Bence Magyar
- Błażej Sowa
- Denis Stogl
- Fabian Immel
- Felix Exner
- Jan-Hendrik Pauls
- Jean-Pierre Busch
- Jordan Palacios
- Jordi Pages
- Jose-Luis Blanco-Claraco
- Josh Whitley
- Paul Gesel
- Roni Kreinin
- SBG Systems
- TIAGo PAL support team
- Tyler Weaver
- Yue Erro
- paul
- rostest
