Package Updates for Humble
Added Packages [30]:
- ros-humble-gtsam: 4.2.0-1
- ros-humble-gtsam-dbgsym: 4.2.0-1
- ros-humble-interactive-marker-twist-server: 2.1.0-2
- ros-humble-interactive-marker-twist-server-dbgsym: 2.1.0-2
- ros-humble-odom-to-tf-ros2: 1.0.2-1
- ros-humble-odom-to-tf-ros2-dbgsym: 1.0.2-1
- ros-humble-openni2-camera: 2.0.1-1
- ros-humble-openni2-camera-dbgsym: 2.0.1-1
- ros-humble-phidgets-analog-outputs: 2.3.1-1
- ros-humble-phidgets-analog-outputs-dbgsym: 2.3.1-1
- ros-humble-play-motion2: 0.0.4-1
- ros-humble-play-motion2-dbgsym: 0.0.4-1
- ros-humble-play-motion2-msgs: 0.0.4-1
- ros-humble-play-motion2-msgs-dbgsym: 0.0.4-1
- ros-humble-rig-reconfigure: 1.0.0-1
- ros-humble-rig-reconfigure-dbgsym: 1.0.0-1
- ros-humble-schunk-svh-description: 2.1.1-1
- ros-humble-schunk-svh-driver: 2.1.1-1
- ros-humble-schunk-svh-driver-dbgsym: 2.1.1-1
- ros-humble-schunk-svh-library: 1.0.1-1
- ros-humble-schunk-svh-library-dbgsym: 1.0.1-1
- ros-humble-schunk-svh-tests: 2.1.1-1
- ros-humble-stomp: 0.1.2-1
- ros-humble-stomp-dbgsym: 0.1.2-1
- ros-humble-tiago-gazebo-dbgsym: 4.0.2-1
- ros-humble-turtlebot4-cpp-tutorials: 1.0.0-1
- ros-humble-turtlebot4-cpp-tutorials-dbgsym: 1.0.0-1
- ros-humble-turtlebot4-python-tutorials: 1.0.0-1
- ros-humble-turtlebot4-setup: 1.0.2-1
- ros-humble-turtlebot4-tutorials: 1.0.0-1
Updated Packages [112]:
- ros-humble-admittance-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-admittance-controller-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-behaviortree-cpp-v3: 3.8.2-1 β 3.8.3-2
- ros-humble-behaviortree-cpp-v3-dbgsym: 3.8.2-1 β 3.8.3-2
- ros-humble-controller-interface: 2.23.0-1 β 2.24.1-1
- ros-humble-controller-interface-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-controller-manager: 2.23.0-1 β 2.24.1-1
- ros-humble-controller-manager-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-controller-manager-msgs: 2.23.0-1 β 2.24.1-1
- ros-humble-controller-manager-msgs-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-depthai-bridge: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-bridge-dbgsym: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-examples: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-examples-dbgsym: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-ros: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-ros-driver: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-ros-driver-dbgsym: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-ros-msgs: 2.6.3-1 β 2.6.4-1
- ros-humble-depthai-ros-msgs-dbgsym: 2.6.3-1 β 2.6.4-1
- ros-humble-diff-drive-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-diff-drive-controller-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-effort-controllers: 2.17.1-1 β 2.17.2-1
- ros-humble-effort-controllers-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-force-torque-sensor-broadcaster: 2.17.1-1 β 2.17.2-1
- ros-humble-force-torque-sensor-broadcaster-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-forward-command-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-forward-command-controller-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-foxglove-bridge: 0.4.1-1 β 0.5.1-1
- ros-humble-foxglove-bridge-dbgsym: 0.4.1-1 β 0.5.1-1
- ros-humble-gazebo-ros2-control: 0.4.1-1 β 0.4.2-1
- ros-humble-gazebo-ros2-control-dbgsym: 0.4.1-1 β 0.4.2-1
- ros-humble-gazebo-ros2-control-demos: 0.4.1-1 β 0.4.2-1
- ros-humble-gazebo-ros2-control-demos-dbgsym: 0.4.1-1 β 0.4.2-1
- ros-humble-gripper-controllers: 2.17.1-1 β 2.17.2-1
- ros-humble-gripper-controllers-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-gurumdds-cmake-module: 3.3.1-1 β 3.4.0-1
- ros-humble-hardware-interface: 2.23.0-1 β 2.24.1-1
- ros-humble-hardware-interface-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-imu-sensor-broadcaster: 2.17.1-1 β 2.17.2-1
- ros-humble-imu-sensor-broadcaster-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-joint-limits: 2.23.0-1 β 2.24.1-1
- ros-humble-joint-limits-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-joint-state-broadcaster: 2.17.1-1 β 2.17.2-1
- ros-humble-joint-state-broadcaster-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-joint-trajectory-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-joint-trajectory-controller-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-libphidget22: 2.3.0-2 β 2.3.1-1
- ros-humble-libphidget22-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-libstatistics-collector: 1.3.0-1 β 1.3.1-1
- ros-humble-libstatistics-collector-dbgsym: 1.3.0-1 β 1.3.1-1
- ros-humble-mrpt2: 2.6.0-1 β 2.7.0-1
- ros-humble-mrpt2-dbgsym: 2.6.0-1 β 2.7.0-1
- ros-humble-mvsim: 0.5.1-2 β 0.6.1-1
- ros-humble-mvsim-dbgsym: 0.5.1-2 β 0.6.1-1
- ros-humble-phidgets-accelerometer: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-accelerometer-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-analog-inputs: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-analog-inputs-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-api: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-api-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-digital-inputs: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-digital-inputs-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-digital-outputs: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-digital-outputs-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-drivers: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-gyroscope: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-gyroscope-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-high-speed-encoder: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-high-speed-encoder-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-ik: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-magnetometer: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-magnetometer-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-motors: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-motors-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-msgs: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-msgs-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-spatial: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-spatial-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-temperature: 2.3.0-2 β 2.3.1-1
- ros-humble-phidgets-temperature-dbgsym: 2.3.0-2 β 2.3.1-1
- ros-humble-position-controllers: 2.17.1-1 β 2.17.2-1
- ros-humble-position-controllers-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-py-trees-js: 0.6.3-1 β 0.6.4-1
- ros-humble-rc-genicam-api: 2.5.12-3 β 2.6.1-1
- ros-humble-rc-genicam-api-dbgsym: 2.5.12-3 β 2.6.1-1
- ros-humble-rmw-gurumdds-cpp: 3.3.1-1 β 3.4.0-1
- ros-humble-rmw-gurumdds-cpp-dbgsym: 3.3.1-1 β 3.4.0-1
- ros-humble-ros2-control: 2.23.0-1 β 2.24.1-1
- ros-humble-ros2-control-test-assets: 2.23.0-1 β 2.24.1-1
- ros-humble-ros2-controllers: 2.17.1-1 β 2.17.2-1
- ros-humble-ros2-controllers-test-nodes: 2.17.1-1 β 2.17.2-1
- ros-humble-ros2controlcli: 2.23.0-1 β 2.24.1-1
- ros-humble-rqt-controller-manager: 2.23.0-1 β 2.24.1-1
- ros-humble-rqt-joint-trajectory-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-tiago-bringup: 4.0.2-1 β 4.0.3-1
- ros-humble-tiago-controller-configuration: 4.0.2-1 β 4.0.3-1
- ros-humble-tiago-description: 4.0.2-1 β 4.0.3-1
- ros-humble-tiago-gazebo: 4.0.1-1 β 4.0.2-1
- ros-humble-tiago-robot: 4.0.2-1 β 4.0.3-1
- ros-humble-tiago-simulation: 4.0.1-1 β 4.0.2-1
- ros-humble-transmission-interface: 2.23.0-1 β 2.24.1-1
- ros-humble-transmission-interface-dbgsym: 2.23.0-1 β 2.24.1-1
- ros-humble-tricycle-controller: 2.17.1-1 β 2.17.2-1
- ros-humble-tricycle-controller-dbgsym: 2.17.1-1 β 2.17.2-1
- ros-humble-turtlebot4-description: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-msgs: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-msgs-dbgsym: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-navigation: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-node: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-node-dbgsym: 1.0.0-1 β 1.0.1-1
- ros-humble-velocity-controllers: 2.17.1-1 β 2.17.2-1
- ros-humble-velocity-controllers-dbgsym: 2.17.1-1 β 2.17.2-1
Removed Packages [0]:
- Adam Serafin
- Alejandro Hernandez
- Bence Magyar
- Daniel Stonier
- Davide Faconti
- Denis Ε togl
- Felix Ruess
- Frank Dellaert
- George Stavrinos
- John Hurliman
- Jordan Palacios
- Jordi Pages
- Jorge Nicho
- Jose-Luis Blanco-Claraco
- Martin GΓΌnther
- Michael Ferguson
- Mike Purvis
- Noel Jimenez
- ROS Tooling Working Group
- Sachin Guruswamy
- Stefan Scherzinger
- Team Spatzenhirn
- Youngjin Yun
- rkreinin
- sachin
