We’re happy to announce 4 new packages and 37 update for Kinetic.
Thank you to everyone who helped make this possible, including the maintainers and all the contributors. Full details are below.
Package Updates for kinetic
Added Packages [4]:
- ros-kinetic-gundam-robot: 0.0.3-1
- ros-kinetic-gundam-rx78-control: 0.0.3-1
- ros-kinetic-gundam-rx78-description: 0.0.3-1
- ros-kinetic-gundam-rx78-gazebo: 0.0.3-1
Updated Packages [37]:
- ros-kinetic-astuff-sensor-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-costmap-cspace: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-costmap-cspace-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-delphi-esr-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-delphi-mrr-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-delphi-srr-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-derived-object-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-ibeo-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-joystick-interrupt: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-kartech-linear-actuator-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-map-organizer: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-map-organizer-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-mavlink: 2019.12.30-1 -> 2020.2.2-1
- ros-kinetic-mcl-3dl: 0.2.0-1 -> 0.2.1-1
- ros-kinetic-mobileye-560-660-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-neobotix-usboard-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-neonavigation: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-neonavigation-common: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-neonavigation-launch: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-neonavigation-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-obj-to-pointcloud: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-pacmod: 2.0.2-0 -> 2.1.0-1
- ros-kinetic-pacmod-game-control: 2.3.0-0 -> 3.0.1-1
- ros-kinetic-pacmod-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-pacmod3: 1.2.1-0 -> 1.3.0-1
- ros-kinetic-planner-cspace: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-planner-cspace-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-plotjuggler: 2.5.0-1 -> 2.5.1-2
- ros-kinetic-radar-msgs: 2.3.1-0 -> 3.0.1-1
- ros-kinetic-rcdiscover: 1.0.0-1 -> 1.0.2-1
- ros-kinetic-safety-limiter: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-safety-limiter-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-track-odometry: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-trajectory-tracker: 0.6.0-1 -> 0.7.0-1
- ros-kinetic-trajectory-tracker-msgs: 0.5.0-1 -> 0.7.0-1
- ros-kinetic-urg-stamped: 0.0.3-1 -> 0.0.4-1
- ros-kinetic-visualstates: 0.2.2-0 -> 0.2.3-2
Removed Packages [0]:
- Atsushi Watanabe
- AutonomouStuff Software Team
- Davide Faconti
- Felix Ruess
- Kei Okada
- Okan Aşık
- Vladimir Ermakov
