Weβre happy to announce the next update of ROS Melodic. There are 18 new packages as well as 108 updated packages. Full details are below.
Package Updates for melodic
Added Packages [18]:
- ros-melodic-can-dbc-parser: 1.0.0-3
- ros-melodic-dijkstra-mesh-planner: 1.0.0-3
- ros-melodic-drone-assets: 1.3.6-1
- ros-melodic-explore-lite: 2.1.4-1
- ros-melodic-graceful-controller: 0.3.0-1
- ros-melodic-graceful-controller-ros: 0.3.0-1
- ros-melodic-heifu: 0.7.7-2
- ros-melodic-heifu-bringup: 0.7.7-2
- ros-melodic-heifu-description: 0.7.7-2
- ros-melodic-mbf-mesh-core: 1.0.0-3
- ros-melodic-mbf-mesh-nav: 1.0.0-3
- ros-melodic-mesh-controller: 1.0.0-3
- ros-melodic-mesh-layers: 1.0.0-3
- ros-melodic-mesh-map: 1.0.0-3
- ros-melodic-mesh-navigation: 1.0.0-3
- ros-melodic-multirobot-map-merge: 2.1.4-1
- ros-melodic-rviz-satellite: 3.0.3-1
- ros-melodic-wave-front-planner: 1.0.0-3
Updated Packages [108]:
- ros-melodic-ackermann-steering-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-actionlib-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-async-web-server-cpp: 0.0.3-0 β 1.0.2-1
- ros-melodic-audio-capture: 0.3.9-1 β 0.3.10-1
- ros-melodic-audio-common: 0.3.9-1 β 0.3.10-1
- ros-melodic-audio-common-msgs: 0.3.9-1 β 0.3.10-1
- ros-melodic-audio-play: 0.3.9-1 β 0.3.10-1
- ros-melodic-axis-camera: 0.3.0-1 β 0.3.1-1
- ros-melodic-common-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-costmap-cspace: 0.10.4-1 β 0.10.5-1
- ros-melodic-diagnostic-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-diff-drive-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-drone-wrapper: 1.3.2-5 β 1.3.6-1
- ros-melodic-effort-controllers: 0.17.1-1 β 0.17.2-1
- ros-melodic-force-torque-sensor-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-forward-command-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-four-wheel-steering-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-geometry-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-grid-map: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-core: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-costmap-2d: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-cv: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-demos: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-filters: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-loader: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-msgs: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-octomap: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-pcl: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-ros: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-rviz-plugin: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-sdf: 1.6.2-1 β 1.6.4-2
- ros-melodic-grid-map-visualization: 1.6.2-1 β 1.6.4-2
- ros-melodic-gripper-action-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-heifu-diagnostic: 0.7.2-1 β 0.7.7-2
- ros-melodic-heifu-mavros: 0.7.2-1 β 0.7.7-2
- ros-melodic-heifu-msgs: 0.7.2-1 β 0.7.7-2
- ros-melodic-heifu-safety: 0.7.2-1 β 0.7.7-2
- ros-melodic-heifu-simple-waypoint: 0.7.2-1 β 0.7.7-2
- ros-melodic-heifu-tools: 0.7.2-1 β 0.7.7-2
- ros-melodic-imu-sensor-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-jderobot-drones: 1.3.2-5 β 1.3.6-1
- ros-melodic-joint-state-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-joint-trajectory-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-joystick-interrupt: 0.10.4-1 β 0.10.5-1
- ros-melodic-leo: 1.1.0-1 β 1.2.1-1
- ros-melodic-leo-bringup: 1.1.2-1 β 1.1.3-1
- ros-melodic-leo-description: 1.1.0-1 β 1.2.1-1
- ros-melodic-leo-desktop: 0.2.2-1 β 0.2.3-1
- ros-melodic-leo-fw: 1.1.2-1 β 1.1.3-1
- ros-melodic-leo-gazebo: 0.1.3-1 β 0.2.0-1
- ros-melodic-leo-robot: 1.1.2-1 β 1.1.3-1
- ros-melodic-leo-simulator: 0.1.3-1 β 0.2.0-1
- ros-melodic-leo-teleop: 1.1.0-1 β 1.2.1-1
- ros-melodic-leo-viz: 0.2.2-1 β 0.2.3-1
- ros-melodic-libmavconn: 1.5.0-1 β 1.5.1-1
- ros-melodic-librealsense2: 2.40.0-1 β 2.41.0-1
- ros-melodic-map-organizer: 0.10.4-1 β 0.10.5-1
- ros-melodic-mavlink: 2020.12.12-1 β 2021.1.4-1
- ros-melodic-mavros: 1.5.0-1 β 1.5.1-1
- ros-melodic-mavros-extras: 1.5.0-1 β 1.5.1-1
- ros-melodic-mavros-msgs: 1.5.0-1 β 1.5.1-1
- ros-melodic-mcl-3dl: 0.5.1-1 β 0.5.2-1
- ros-melodic-mesh-client: 1.0.0-1 β 1.0.0-3
- ros-melodic-moveit-python: 0.3.4-1 β 0.3.5-1
- ros-melodic-mqtt-bridge: 0.1.7-7 β 0.1.8-4
- ros-melodic-nav-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-neonavigation: 0.10.4-1 β 0.10.5-1
- ros-melodic-neonavigation-common: 0.10.4-1 β 0.10.5-1
- ros-melodic-neonavigation-launch: 0.10.4-1 β 0.10.5-1
- ros-melodic-novatel-oem7-driver: 1.1.0-1 β 2.0.0-1
- ros-melodic-novatel-oem7-msgs: 1.1.0-1 β 2.0.0-1
- ros-melodic-obj-to-pointcloud: 0.10.4-1 β 0.10.5-1
- ros-melodic-planner-cspace: 0.10.4-1 β 0.10.5-1
- ros-melodic-plotjuggler: 3.0.5-2 β 3.0.7-1
- ros-melodic-position-controllers: 0.17.1-1 β 0.17.2-1
- ros-melodic-psen-scan-v2: 0.1.3-1 β 0.1.4-1
- ros-melodic-py-trees: 0.6.8-0 β 0.6.9-1
- ros-melodic-realsense2-camera: 2.2.20-1 β 2.2.21-1
- ros-melodic-realsense2-description: 2.2.20-1 β 2.2.21-1
- ros-melodic-ros-controllers: 0.17.1-1 β 0.17.2-1
- ros-melodic-rqt-drone-teleop: 1.3.2-5 β 1.3.6-1
- ros-melodic-rqt-ground-robot-teleop: 1.3.2-5 β 1.3.6-1
- ros-melodic-rqt-joint-trajectory-controller: 0.17.1-1 β 0.17.2-1
- ros-melodic-safety-limiter: 0.10.4-1 β 0.10.5-1
- ros-melodic-sensor-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-shape-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-sound-play: 0.3.9-1 β 0.3.10-1
- ros-melodic-stereo-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-test-mavros: 1.5.0-1 β 1.5.1-1
- ros-melodic-track-odometry: 0.10.4-1 β 0.10.5-1
- ros-melodic-trajectory-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-trajectory-tracker: 0.10.4-1 β 0.10.5-1
- ros-melodic-turtlebot3: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-bringup: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-description: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-example: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-fake: 1.2.0-0 β 1.3.1-1
- ros-melodic-turtlebot3-gazebo: 1.2.0-0 β 1.3.1-1
- ros-melodic-turtlebot3-navigation: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-simulations: 1.2.0-0 β 1.3.1-1
- ros-melodic-turtlebot3-slam: 1.2.4-1 β 1.2.5-1
- ros-melodic-turtlebot3-teleop: 1.2.4-1 β 1.2.5-1
- ros-melodic-variant: 0.1.5-0 β 0.1.6-1
- ros-melodic-variant-msgs: 0.1.5-0 β 0.1.6-1
- ros-melodic-variant-topic-tools: 0.1.5-0 β 0.1.6-1
- ros-melodic-velocity-controllers: 0.17.1-1 β 0.17.2-1
- ros-melodic-visualization-msgs: 1.12.7-0 β 1.12.8-1
- ros-melodic-ypspur-ros: 0.3.1-1 β 0.3.4-1
Removed Packages [0]:
- Alexander Gutenkunst
- AndrΓ© Ferreira
- Atsushi Watanabe
- Austin Hendrix
- Bence Magyar
- BΕaΕΌej Sowa
- Chris Iverach-Brereton
- Daniel Stonier
- Davide Faconti
- FΓ‘bio Azevedo
- Jiri Horner
- Junya Hayashi
- Masaru Morita
- Maximilian Wulf
- Michael Ferguson
- Michel Hidalgo
- New Eagle
- Nikhil Khedekar
- NovAtel Support
- Pedro Arias
- Sachin Chitta
- Samuel Bachmann
- Sebastian PΓΌtz
- Sergey Dorodnicov
- Tim Clephas
- Timo RΓΆhling
- Vincent Rousseau
- Vladimir Ermakov
- Will Son
