New RCLC parameter server features
RCLC parameter server implementation has been refactored in version v3.0.8-rolling.
This upgrade has been implemented to add ROS 2 parameters features to the micro-ROS default user API, the RCLC.
As you know, micro-ROS supports a partial implementation of parameters in order to allow users to tailor the memory used by their embedded micro-ROS application. Sometimes, those kinds of optimizations make it necessary to cut off some interesting features.
During the lifetime of the first approach to the micro-ROS parameter server implementation available in micro-ROS Foxy and Galactic, the micro-ROS community has been providing feedback that have allowed us to prepare a major refactor for micro-ROS Rolling & Humble.
The new features are:
  • Removing parameters. Now micro-ROS parameters can be deleted via the common ros2 param delete.
  • Adding new undeclared parameters. By means of using ros2 param set on a non-existent parameter will create a new parameter if there is enough preallocated memory for it and allow_undeclared_parameters is enabled in configuration.
  • Parameter server on_change callback allows to reject parameter modification, creation or deletion.
    • Improved ros2 param describe integration with parameter description, constraints and read only support.
  • New extra low memory mode that allows an even lower memory footprint of the parameter server implementation at expense of disabling some features**
As a reference, a 7 parameter server with RCLC_PARAMETER_MAX_STRING_LENGTH = 50 and notify_changed_over_dds = true in an STM32F4 will take about 12 kB in normal mode and about 4 kB in the new extra low memory mode.
  • Take a look at an example of the new micro-ROS parameter server API.
  • Check the documentation related to the micro-ROS parameter server.
Very nice.
Are there plans to support string parameters as well?
We do not have plans for it due to issue with handling string length in the MCU static memory, but if you have any proposal please open a PR.
Is there an issue tracking this? Perhaps also with details on what the problems/challenges are?
No, feel free to open it in RCLC repo
