Open Hardware / Low Cost Electric Gripper - the AR Gripper
After searching for solutions for a long time and trying out a couple of the existing grippers, I came to the conclusion that there is a need for a reasonably priced electric gripper. Moreover, all grippers on the market are relatively small for common tasks, such as a gripping a bottle for example. For this particular task I needed something capable of gripping 90mm width and 1.5kg heavy bottles, most grippers, even the ones who cost 3000€+ can’t do that. The cheapest one capable of gripping such a payload was the EZgripper, but as underactuated gripper it has its own flaws.
This is why I started to work on a new gripper, the AR (Alex Rössler) Gripper. How hard can it be?
It turned out parallel grippers are relatively simple devices. The key part is a so-called smart servo. Luckily, I found a vendor with very strong and reasonably priced smart servos.
The rest of the gripper parts can be parametrized and 3D printed. Total hardware cost ~150-200€. However, the gripper fingers and sled might be better manufactured out of metal. I had several made out of Colorfabb Carbon XT material break.
Everything is nicely integrated with ROS of course. URDF files, gripper driver and simulation dummy.
Does this sound like something the ROS/robotics community is interested in?
Pictures and videos will follow.
PS: I wasn’t sure if this is the right category.
Hi Alexander,
When we will see the pictures and videos?
Very much interested!
Here is the first draft, I still need to create good videos and measure the specs: AR Gripper Wiki
That’s super cool! Thanks for following up. I would love to see some good videos and maybe drop them in the weekly update.
Also, if I take off my Open Robotics hat, and put on my Open Source Hardware Association hat, may I suggest that when you are ready you certify your design as open hardware. I am always happy to answer documentation related questions.
Sounds good, I will post some videos soon.
Very interesting, I didn’t know that this exists.
How much does the first prototype weigh, including actuator?
I measured 570g on one of the prototypes. 465g the body (PETG) and actuator and 105g the gripper fingers (XT CF-20).
Had to update my Wiki link:
AR Gripper Wiki
Since there has been some demand for the F360 models, I moved the project to Printables: AR Gripper - Open Hardware Adaptive Electric Parallel Robot Gripper by machinekoder | Download free STL model | Printables.com
Awesome! I’ve bookmarked it and given it a like. :slight_smile:
